Hello everyone, I upgraded to the latest firmware on route10 “1.3z”. I wanted to know if any of you can guide me on how to modify the load-balancing rules on the unit. Thanks in advance.
At time load balancing is activated by setting both WAN metrics to the same number. There is no tuning beyond that.
Thank you for your response. I am curious if alta labs will add more features to modify the load balancing parameters. I use the unit for a very basic function (load balancing) with multi-gig ISPs. I spoke with someone from support yesterday and was told to try to use SSH and see if I could do some modifications on my own, but to be honest I have not tried to use SSH and still very “green” on programming the unit. Thanks again!
