I cannot load any websites from Brave browser after the update. Every site is blocked as being unsafe (non HTTPS). Also, my work laptop no longer loads Slack on my home network
Whatever has happened is not good. On web browser all I get is a page to login to Comcast via mobile app. This is on desktop. Brave search site won’t even load.
Whatever happened last night is terribly disruptive. I’ve never had these problems before on my network, ever.
Do you recall if you came from 1.5m? 1.5n was a pretty small release, isolated to the fixed Linux kernel vulnerability and shouldn’t have affected traffic in any capacity.
I don’t have any block lists. Everything is pretty close to default settings. I see the route 10 as dhcp services, so it goes from my modem to route 10 and then to my Wi-Fi router. One other connection from route 10 goes to my PC via Ethernet, no wifi. Pretty simple
It appears that route 10 has blocked the internet, it doesn’t matter what browser or wifi device, it’s all blocked. Something happened between 10pm and 6am this morning.
I’m going to remove route 1p and see if that will resolve the issue of no Internet on the WiFi devices.
I can say with fair certainty that if there was a change in this firmware that broke DHCP in any capacity, the firmware never would’ve been pushed out. I would certainly qualify whatever you encountered as a corner case.
I’ll be happy to take a look, with or without the Route10 in production (it can just be a node on the network) to see if I can find whatever is causing the issue.
