Route10 Firmware 1.4t Released!
This release expands firewall functionality, strengthens network protection, and improves multi-WAN performance.
  • Add support for firewall IP and port groups.
  • Add support for IDS/IPS inline mode (Settings->Firewall->Intrusion Prevention), to block threats immediately.
  • Improve Multi-WAN handling.
Lets gooooo.
Thank you for adding IP and Port Groups. That is a very helpful addition.
I also spotted that @Alta-cmb happened to post this in the Alta Labs Reddit regarding features that are coming up after this nice little update :slight_smile:
Thanks! Lot more good stuff is on the way too. Firewall groups and inline IPS just launched this week. Policy routing is in review and will be coming soon. I just finished hostname and wildcard domain support in firewall groups (for use with firewall rules, NAT, and PBR) today, coming soon. Many great things you can’t see as well, like always-expanding automated testing. As well as much more to come this year.
https://www.reddit.com/r/AltaLabs/comments/1re2uh4/comment/o79q0gg/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Any plans to update the local controller? You have been pushing new features only for users on the cloud console; the local one is still on 1.1p and not able to use those features.
According to @Alta-Jeff in the latest live stream they’re hoping to have a local controller update out by the end of the week
this firmware brakes the VPN / none off the clients can connect / site to site is working but L2TP is not
With regards to the inline ips, can you comment more on the performance impact?
The help just says:
Inline mode only allows traffic to pass after full evaluation by the IPS. This has significant performance overhead, and reduces achievable throughput.
After updating to 1.4t, I am witnessing intermittent internet disconnects. Has anyone had the same symptom?
