Route10 Firmware 1.4n Released!
This update delivers key improvements that enhance routing stability and provide more accurate visibility across your network.
  • Add support for IPsec tunnel IP address.
  • Resolve IPv4 Internet access when utilizing dynamic routes.
  • Resolve issues with incorrect VLAN reporting for wired devices.
VLANs look correct now. Yay!
Two things:
  1. Every time my router has auto updated it has failed to return to service on the reboot, requiring a power cycle to get it back operational. It appears to be an issue with the SFP. This is the 3rd time its happened. Aside from disabling auto-update is there anything else I can do?
  2. With UDP acceleration being disabled since “L”, I’ve had to reapply the echo command and reboot each time the OS was updated. Is there any way around that?
  1. Please work with our Support on providing your specific SFP transceiver and endpoint, to see if there is something we can do to improve this.
  2. You can add that command to the /cfg/post-cfg.sh file, and it will run after every configuration, and last through reboots/updates.
Yes - thank you. Vlans look correct now. Can someone explain to me why when a firmware is applied and the router reboots or even when I do a manual reboot of the router myself I am required to toggle between its original state of disabled hw acceleration and enabled hw acceleration before returning to disabled hw accelleration before my smart light and heating switches come online. This is a huge pain in the arse. Actually since 1.4n was installed it no longer works and the switches remain offline
Have you worked with support on resolving the smart lights issue?
