Route10 Firmware 1.3x Released!
We’ve rolled out a new firmware update for Route10, which brings the following improvements:
  • Detect/display IPs for devices with static IPs
  • Resolve issue with firewall rule not honoring source IP/subnet
  • Resolve issue with DHCPv6 over PPPoE
  • Add support for WireGuard client without PSK (controller support pending)
I can confirm the " * Detect/display IPs for devices with static IPs" is working for me. I am able to put a machine on DHCP, see the address, set it to static, and watch the address change in the devices page now.
*EDIT: It still blows me away that my standard windows 11 PC does not show a name though. The Name just gets set to the MAC address.
And the following fix
seems to have solved the missing source IP in the port forward rules. I can confirm that the redirect rule (from uci show firewall | grep redirect) now shows the intended source IP. :+1:
:clap::clap: updated all good :slight_smile:
Next update improved multi WAN with multi static WAN IPs :eyes:
Thank you!
