Route10 Firmware 1.3s Released!
The latest firmware update for Route10 brings the following improvement:
  • Add IDS/IPS Support
Updated quick and its running! Nice work.
Nice quick update and up and running in no time. Excellent work as always Alta.
I really appreciate the ignore feature on the rules, thanks Alta team!
Is this same as deep packet inspection DPI?
Initial speed tests for IDP/IPS are EXTREMELY impressive. The CPU isn’t even breaking a sweat on my gigabit connection. Oh U******i, you’re in trouble.
Question… does the wireguard VPN support domain routing? If it does with this update I’m switching back to the route10 again and giving it a run.
Great News! Looks like its Suricata
Is there any documentation about the IDS/IPS feature.?
Please can we have a link to the assoicated documentation from release notes.
Also what is covered by the BLOCK LEVELS?
We need PBR to be implemented
Setup and running,
Had an email alert for Dropbox backup, but nothing showing in the ALERT pop up, clicked it
Running Brave Browser on Macos
I see that I can ignore all IPS: ET INFO ZeroTier Related Activity (udp) traffic. (medium)
Is it possible to ignore only from specific IP addresses?
Doh thanks for telling me
Big fan if this update. feeling safer already lol
Seconded, would like to have this documentation as well.
Thanks for posting about nothing showing in the top right corner. Mine had been showing 0 but had Events once I clicked on it.
I also haven’t been receiving the email alerts but have just noticed there is a checkbox that needs ticking under Settings > Users. I’ve turned them on now!
How do we add exemptions?
As far as I can tell you can’t… you can just tell it to ignore certain warnings but you’d probably want to be able to ignore it for a specific IP which isn’t present currently it would seem. I noticed you can’t isolate bw usage either on the dashboard so you see total bw the router is seeing not say what your WAN is using vs your LAN ports on the router.
Will the shift reboot features be ported to ROUTE 10 control interface?
Awesome to see IPS/IDS. Way to Go Alta!
on a side note; I Love the fact the upgrades take about maybe 30 seconds. Still getting used to the fast response times on that! Thanks again guys!
