Route 10 - Won't connect to Sky ISP
I have been trying for some time to get my Route 10 to connect to the Sky ISP in the UK. They use Option 61 (which I know is not currently supported) and IPV6 PD which I was told is supported but despite numerous reboots and powering down my ONT etc. I still cannot get connected.
I updated the firmware to 1.3J.
I Have switched on IPV6 on the Lan but cannot find anything on the WAN side, am i missing something simple please?
Solved it - the PD settings were hidden away, wierdly all other routers I have had to use /56 but for some reason that did not work and I ended up using /64. Will provide some more info later incase anyone else has similar issues.
Does the attached image represent the experience you had to discover for setting up the Prefix Delegation?
Yes - thank you.
I am now stuck with an issue where my internet is IPV6 only - I have no IPV4 address which means only half of my devices work.
I have found out that my connection for some reason has moved to MAP-T which I am guessing is not supported at the moment hence why i did not get an IPV4 WAN address so moving back to OPNsense for the meantime, fingers crossed it will be included soon.
I have noticed an update in firmware so trying again on 1.3k.
I have IPV6 on the WAN but no IP4 at the moment sadly, will keep it connected for a few hours to see if it sorts itself out but suspect I need to wait until option 61 is added.
