Route 10 review
ok first off very nice smooth and same size as my iphone 15 pro max size tho an inch or 2 bigger smooth good quality plug and adapter all good mounting still yet to mount this
now slight issue with plug wish i could plugin to my pdu strip as its all kettle cable will reach out to you soon
top of box
open box
front view
mount
screws mounting
Power plug with multi adaptor
QSG
also to cut down on electrical waste can you supply th country only power adaptor with it as im in uk the eu and us i do not need as its a waste of packaging
