Route 10 Map not showing all devices
A few weeks back, they were displayed in the map, now no longer. They do display under devices however, these are hardwired into the unmanaged switch. I’ve tried rebooting a few times and waited a few days for self heal lol but no luck.
Network
ISP > Route 10 > L1 Unmanaged Switch
ISP > Route 10 > L2 Nest WiFi
Not sure how to edit post for new tags, forgot to tag “bug-report”.
Moderators, can you please tag this correctly to “bug-report”.
Anybody have any suggestions on this?
Is that Nest Wifi Router doubble natting ?
It is but that’s not the issue. I’m not seeing the switch and the connected devices. You can see in the drop down though that they’re there.
IMO< this sounds like a double nat issue where it can go one way but not the other. Are you able to use the “LAN” port for the wifi unit with DHCP turned off ?
The switch is directly plugged into route10. Not related to the nest Wi-Fi.
