Question to the forum has anybody tried to power the router from a DC power source just using a barrel connector and flying leads to the DC source? I ask because the AC/DC transformer is pretty large to fit inside of an On-Q enclosure, but I can fit a AC/DC Mean Well and power both the router and switch and save a lot of space.
That would create a dangerous precedent, isn’t it? ![]()
So, with the caveat that I would not reccomend this at all unless you are very familiar with all the weird and wonderful ways that DC power supplies can go wrong, and you are familiar with what your local juristiction’s electrical regulations permit you to do safely:
I have used correctly-rated DIN rail power supplies and DC-DC converters for this purpose previously - mostly in industrial settings e.g powering out-of-band connectivity at optical amplifier sites off the -50V telco power. Note that DIN rail PSUs are not appropriate for use inside e.g an On-Q enclosure - most of them do not have the appropriate insulation at the mains terminals to comply with local laws for residential installation.
If you are going to do something like this, you must include an automotive-style 1A blade fuse or resettable circuit breaker in the positive leg of the power to the Route10. This is not optional, becuase you will not have the overcurrent protection provided by the Alta-provided power supply; you absolutely do not want to start a fire inside your walls because you’ve not included appropriate overcurrent protecton.
If (and only if) you find yourself blowing the 1A fuse (e.g, you’re really pushing the PoE capacity of the Route10), you can up this to 2A. Make sure the fuse is not rated higher than what your PSU can provide, otherwise it’ll never blow and just sit there sizzling instead.
(As an aside: If you were perhaps throwing together an Alta-based network for a site which is backhauled over radio and routinely loses grid power, you might be tempted to power your Route10 using a passive PoE splitter off one of the 54V PoE outputs of the WISP-focused UPS/Switch powering the radio, and you might find it worked surprisingly well until! Not that anyone I know has done this
Again: you do this at 100% your own risk. I don’t expect Alta to support you if you burn your house down or blow up your router!
I would be happy if there was a non-poe variant of the Route 10 powered from +12VDC.
