Is there a command to perform a factory reset on the AP6-PRO from the CLI? I’m trying to avoid having to take the access point down from the ceiling.
/lib/sh/factory-reset
This will work via shell, on any Alta device.
EDIT: sorry, I forgot the .sh was dropped. Fixed.
I tried this and it doesn’t reset. The device is still in the controller with devices connected and responding to pings on its management ip addr. Below is the output returned after running the command.
Pretty sure it needs a restart after but can’t recall
That did the trick.
