Hi,
I was wondering: Is it possible to reach the SSH console also via remote (e.g. via manage.alta.inc)?
This could be useful if you want to debug some things from the distance.
Hi,
If you need to get to the CLI of a particular network device, the fastest way is navigate to the “Network” tab, then hold shift and click on the name of the device. It should bring up the busybox console for said device.
Thanks a lot, really saved my day. Had to remotely reboot my fiber router, which was not anymore accessible via its public IP.
