Hi, I am interested in purchasing a couple of the pro AP points for my home. But I need a router, I currently have a Draytek VDSL modem on Eero Pro 6 units, I’m in the UK and have a PPPOE connection, fibre is on its way. So I would like a router that can power the AP’s over POE, give me a firewall and the ability to setup the PPPOE and future fibre connections. Will your up coming 8 port switch do this? Or would I need something else, if so does anyone have any recommendations. I only need 5 or 6 ports.
Would an Edge router work? Are they easy to setup? I had Ubiquiti Dream Machine and Dream Router before with an AP, but never had an Edge router.
If you will grant me the liberty of my 2 cents… I would strongly suggest looking at PFSense or OpnSense for your router. The EdgeRouter has not had any attention given to it for a good long time now. If you are going to learn something new, that is not the router to pick. You are not going to find a “good” router, POE switch combo that will be worth the money. I would go for PFSense, an Alta POE switch, and Alta APs for now.
Thanks for the reply, not sure I want to go down that route. I am looking for something that is easy to configure and I’m not sure PSsense etc is is it? Plus I don’t want any large boxes, as small as possible would do. I mean what options are there for going down that route that’s easy to use and not expensive? I would assume the 8 port switch is around £150, the AP’s are around £170 each.
I’ve never seen let along used PFsense or Opnsense in my life! It would be totally new to me.
I would buy a seperate POE+ switch. Most provider routers don’t have POE and also have max of 4 ports.
An extra 8 ports POE+ switch will give you more flexibilty.
Opnsense/Pfsense has a steeper learning curve. If you want to have a rock solid CPE, I would go for the AVM Frtizbox boxes.
Seems like pfsense (or opsense) is the way to go. I’m still investigating a few easy alternatives for failover but this is still in the running, thanks!
Works for me, but I use Eero currently. I was asking for advice on a router with built in firewall, ability to set up PPPOE connections etc like an Eero does, and supplies POE for the access points, and members advised me to separate everything out. I have a Draytek modem not router.
Not a bad option, shame it lacks POE. I think the Ubiquit Dream Machine Pro SE is the best option looking at everything. But Ubiquiti aren’t the most reliable with their firmware updates.
Hi, would something like this work? I could remove my modem then, would it work well then with a fibre connection using an ONT later on? Don’t need dual WAN. If my broadband goes down I just use my 5G on my phone.
I see Draytek have some new interface too, I always found their interface rather lacking compared to Unifi before.
