Question about WPA-PSK on the pro
Hello,
I have been looking into the items you offer.
On this moment my network is build around a Draytek router, Draytek switch, Mikrotik 10gb switch and some older Zyxel 1gb POE swithes. I also have a few Draytek accesspoints.
When I compared the Draytek the Unifi Wifi accesspoints.
Draytek was a bit slower but more stable.
Now that I look to the ALTA lab A6 and A6pro, I found something weird in the documents, that the A6pro does not support security on a WPA/PSK level?
Generally I would not use that, but as the thermostat of my central healing only talks 2.4 ghz and wpa/psk, I know that I need that.
But I put that thermostat, with other IOT items on different Vlan, so it does not interfere on my main vlan.
So the question is, does the A6Pro support WPA/PSK? Maybe I did misread the documentation.
RobB
Hi @emisary and welcome to the community!
I’ll review the datasheet but the APs 100% support WPA2-PSK as well as a WPA3-PSK option.
But over here I read: AP6
Wireless Security: WPA-PSK, WPA-Enterprise (WPA2/WPA3)
And here I read:AP6 Pro
Wireless Security: WPA2-PSK, WPA3-PSK, WPA-Enterprise (WPA2/WPA3
So there is a difference, or I read it incorrect.
The device, which is not that old, does not work with WPA2 or higher.
RobB
That’s simply a documentation error, we’ll get that corrected. The corrected terminology is WPA2-PSK, WPA3-SAE, WPA-Enterprise (WPA2/WPA3)
So you have a device that won’t associate when WPA2 is set with a password?
Thank’s for checking that.
Please don’t laugh. I made a mistake.
I thought I had it on WPA. I just did check it. I have it on WPA2.
I also did check a 2 gen older Vigor 902, which is not in use anymore, and that one was set to WPA. So I had that in my mind.
The newer Vigor 906, which is now in use, is on WPA2-PSK for IOT. The rest is on WPA2/WPA3.
By the way, the error was also in a comparing page.
And in the Datasheet.
RobB
No worries at all! I’m glad it’s working for you as intended.
Thank you for the links, I’ve shared them internally and the information should be corrected in short order!
