Problems with wifi
Hi!!! I have detected that some devices are connecting to access points that are farther away and have less coverage, even when there are access points right next to them! Is there a way to fix this?
It’s mainly on the client to pick which AP to connect to. If you have multiple APs you may try lowering the transmit power on each one to try to encourage clients to connect to the closer AP.
