A minor suggestion for improving the Device list in the WebUI:
The wired devices/ports negotiated link speed could be printed in the TX/RX Rate column. Now it says None/None for wired devices. The column name might perhaps then need a change to Link Rate/Speed, but I guess that would also work for wireless devices?!
Or, else, this could perhaps be printed in the Signal column by switching a setting under Settings → Wrench → Appearance, like the WiFi signal between Icon/Raw (combine with the existing or a new setting).
I know the ethernet link speed can be found by hovering over the Ethernet port icons in the Signal column, but I thought it wouldn’t hurt to make use of the unused None/None value. ![]()
