I have a small rant that I’m very upset about for no reason, but it makes my blood boil. The S8 uses a huge power adapter, which is fine, because the way the AC prongs are turned 90d. The Route10 uses the same power supply, but has interchangeable tips, but they go the opposite direction as the S8. So, if you plug an S8 and a Route10 into the same power source, you are taking up 4-6 outlets depending on spacing…for two devices.
If you included the same power supply as the S8, you would only take up two outlets depending on the way the outlets for your power source are oriented.
Luckily, I have a few S8s and I can just use one of those power supplies, but I got super upset for no reason.
That is all. I hope this provided comic relief for some people this weekend.
It just means I have to figure out another way to use my half width PDU in my rack.
