POE Port Disabled when plugging a SPF module
I just received a replacement R10 because the Poe ports appeared to be burned out. I plugged in a SPF module in LAN4 and LAN3 went off. I tried 3 or 4 different ones - RJ45 and fiber - and it happens every time. I left an RJ45 plugged in for several minutes and LAN3 finally came on and powered the AP6. Is this normal behavior for the R10?
Sounds like a faulty sfp module
That would be what I would think except I tried about 4 different modules - which all work in other devices - so it would be really odd that ALL of the them would be defective - but stranger things have happened. Anyway - I plugged in a 10GTEK fiber module and it appears to be working fine.
Maybe more incompatible than faulty then
