Pbr for nextdns when using wireguard?
Using my Route10 for wireguard roadwarrior setup, when I am using Wireguard on my laptop I would like to be able to direct DNS to my NextDNS DoH. Is that possible yet with a PBR or with the new DNS settings?
@Alta-Jeff ? Are you able to chime in on this one by chance?
That’s not necessarily a PBR feature. You could set the DNS option in your WireGuard config to match your Route10 WireGuard server, but then it will use the same servers as the Route10’s proxy for any other DNS traffic. We’re adding an option to force all proxied DNS traffic over the configured DOH servers, which should hopefully accomplish what you want there, and the next release should be out in no less than 2 weeks.
Thank you Jeff. Maybe you have a better suggestion for what I am trying to do. I use NextDNS on all of my mobile devices via installed profiles. However, when using Wireguard VPN, that option is not available, so my traffic travels over “normal DNS”. I am trying to figure out a way to force my wireguard traffic back to my nextDNS. Does that make sense?
I answered my own question here. The wireguard clients have changed enough that you can make this happen at the client level. No need to force anything.
