Hi,
New setup, Route 10 with 8 port switch.
There is no… zero/zero throughput on a guest VM.
On the HOST machine it shows fine.
Any ideas?
EDIT: the host 2 network cards, 1 is for MGMT (HV01)
The other is set as a VSwitch for all vms.
i have an entry in devices that is the VSwitch MAC. this shows the data but seems it cant split it to to the correct VM’s IP/MAC
edit2: for some reason the MAC showing for the HV host and the vswitch are the same despite these being completely different NICs/hardware…
Thanks James.
