New S12 – observations and temperature readings
Our local supply house got the S12s in a few days ago and we got one to test out!
So far, been super impressed with it – easy to install and get set up on a site. We’re currently running ports 1-8 with 10Gb copper transceivers (10GTek) and port 12 is a DAC to a S48 switch.
Some quick observations:
  • Super simple set up like all Alta devices. Got it added to our site and upgraded very easily.
  • Doing an iperf3 test between devices basically gets max speed for 10Gb.
  • Solid connections to devices with native 10Gb cards – Synology DS1821 and Mac Studio Pro
  • 10Gb Thunderbolt docks from OWC seemed to go offline every couple of minutes and back on. The logs reported an STP block. When I changed from Auto configure network interface (on MacOS) to manual with 10Gb full-duplex and jumbo frames, the connection stayed solid and has remained so. Not sure if what I was seeing was the dock, the SFP+ module, or the S12, or some combination of all three. Works fine with manual settings… so that is good.
  • Copper SFP+ transceivers get quite hot. I believe this is pretty normal for copper 10Gb, but it’s hot enough that you wouldn’t want to touch it very long – I’m guessing between 140-170 F (I don’t have an infrared thermometer).
All other Alta switches have a temperature reading, but I didn’t see on the S12 info card. Could this be added? I know most transceivers have temp sensors too. Could this be added as well?
Overall, great product! We’re going to use these for 10Gb networks and video distribution for our clients.
Sounds good man, keep spam checking Wifigear here in the UK hoping they have one in stock for sale. Any day now.
I also use 10GTek copper SFP’s and they get SUPER hot. I’m a bit worried about it affecting the longevity of the switches but so far so good.
Yeah. Super hot is a good description. I wish the switch could read the temperatures from the sensors (assuming the 10Gtek include temperature sensors).
Has anyone here loaded an S12 with only copper sfp’s?
Not fully, but we had 8 in ours. But not all are active at the same time.
