Network is showing my AP's as red, while devices are green
I’m new to Alta, just replaced my old Netgear Orbi setup. Is this normal? Also seeing my Pixel 3XL phone WiFi flapping. I’ve tried with Fast Roaming on & off. I’ve got IGMP Proxy enabled, as well as enabled on my Firewalla Gold. It also seems that whenever I make any changes, the AP’s drop all clients until I unplug / replug them.
That is the same bug i already mentioned. They also replicated it at Alta and working on a fix.
Hang in there.
Okay, thank you for the quick response.
I suspect they are going to find it being related to IGMP Proxy. I do not have that enabled anywhere, and it is smooth sailing.
I’ve tried with IGMP Proxy on and off. I’m also noticing that I’m not able to add smart plugs that operate in the 2.4Ghz realm. It’s a Teckin Smart Socket SP10. Not sure if related, unable to add a new Blink XT2 wireless camera to my existing setup, and noticed that my Green Mountain Grill (first gen Daniel Boone) smoker isn’t connecting to the network as it had before.
@macnmod The red and green colors there are just part of the palette chosen. The colors do not mean anything, it is simply a count of Network Devices vs Connected Devices.
For clients dropping, have you adjusted any of the advanced settings on the SSIDs? For example, there are some settings, such as the minimum rate, which if modified from the defaults, may necessitate taking down and bringing back up the SSID, whereas others do not.
Can you ensure that your SSID settings are reset back to defaults, and let us know if you still have issues with the Blink/smoker?
I’ve got it to only broadcast 2.4GHz, as my phone connection will not stop flapping. I’ve tried IGMP Proxy on/off, doesn’t seem to matter.
@macnmod The only advanced setting I would recommend changing from the default is fast roaming. I would reset all of the others, in nearly all cases. How are you determining that the device is flapping? Do you have a video/screen shot in the controller, etc?
Continuous connect/reconnect when on the 5GHz SSID. Today I created a 5GHz-only network. I watched as my phone went from LTE to WiFi, WiFi to LTE, about every 10-15 seconds. I will try only using fast roaming.
@macnmod Definitely haven’t seen that before but I’m happy to take a look. Can you grab the AP’s logs at the moment this issue is happening? What is the signal strength of our device when this happens? If this is an iOS device, another thing that is helpful is if you can install the Wi-Fi logging profile for iOS here: Profiles and Logs - Bug Reporting - Apple Developer and then grab the logs from the device.
I sent a log file to Matt earlier today of an iPad at my site doing this… not sure if it would help to look at.
It’s an android. Let me see if I can get to my logs. About to upgrade the cores here at the office. Good bye Nexus 9300!!!
I’m not seeing where to get AP logs from the web interface. I’m running android.
@macnmod The best way to grab the logs is to use ssh and scp. You can create an ssh key, and install it into the System Settings in manage.alta.inc, and then you can scp (copy) the /var/log/messages* files from the AP using SCP / WinSCP.
Okay, I’ll give it a go.
I’ve gotten connected, sorry for lagging. What would be some helpful commands to get you info to see this phone flap from the AP?
No worries. Are you connected to the AP via SSH on your Android device? Or? Only thing to be mindful of is that the logs my be truncated compared to what’s in the actual log file itself.
I would suggest rotating your device into landscape orientation to minimize line breaks and then issue the following command: cat /var/log/messages
Please either share here, or feel welcome to send to me via a direct message. Whichever your preference.
Thanks Mike, I’m connecting to AP via windows pc running Putty watching Android phone up/down…
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.08.24 18:34:15 =~=~=~=~=~=~=~=~=~=~=~=
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.302858] wlan: [1413:E:mlme] mlme_cmd_abort: Active cmd not found type:29
Aug 25 01:33:49 OpenWrt daemon.notice wpa_supplicant[12106]: m5: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.303405] wlan: [0:E:ANY] mlme_check_curchan_and_set_ap_pwr_type: Frequency 5180 is not present in LPI chan list
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.303551] wlan: [0:I:ANY] ssid: Cole-Office-5GHz len: 0 bssid:b6:f1:74:73:f5:bb
Aug 25 01:33:49 OpenWrt daemon.info hostapd: 5g6zE9SRcY: IEEE 802.11 driver had channel switch: freq=5180, ht=1, vht_ch=0x0, he_ch=0x0, offset=1, width=3 (80 MHz), cf1=5210, cf2=0
Aug 25 01:33:49 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: CTRL-EVENT-CHANNEL-SWITCH freq=5180 ht_enabled=1 ch_offset=1 ch_width=80 MHz cf1=5210 cf2=0 dfs=0
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.336234] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported BCAST RATE is 6000(kbps) rate code: 0x10000003
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.336304] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported MCAST RATE 6000(kbps), rate code: 0x10000003
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.337074] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported BCAST RATE is 6000(kbps) rate code: 0x10000003
Aug 25 01:33:49 OpenWrt kern.err kernel: [142406.337754] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported MCAST RATE 6000(kbps), rate code: 0x10000003
Aug 25 01:33:49 OpenWrt daemon.notice wpa_supplicant[12106]: m5: WPA: RX message 1 of 4-Way Handshake from b6:f1:74:73:f5:bb (ver=0)
Aug 25 01:33:49 OpenWrt daemon.notice wpa_supplicant[12106]: m5: WPA: Sending EAPOL-Key 2/4
Aug 25 01:33:49 OpenWrt daemon.notice wpa_supplicant[12106]: WPA: Send EAPOL-Key frame to b6:f1:74:73:f5:bb ver=0 mic_len=16 key_mgmt=0x400
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: WPA: RX message 3 of 4-Way Handshake from b6:f1:74:73:f5:bb (ver=0)
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: WPA: Sending EAPOL-Key 4/4
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: WPA: Send EAPOL-Key frame to b6:f1:74:73:f5:bb ver=0 mic_len=16 key_mgmt=0x400
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: WPA: Installing PTK to the driver
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: wpa_driver_nl80211_set_key: ifindex=5414 (m5) alg=3 addr=0x76f4c684 key_idx=0 set_tx=1 seq_len=6 key_len=16 key_flag=0x2c
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: Not validating GTK for mesh
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: WPA: Key negotiation completed with b6:f1:74:73:f5:bb [PTK=CCMP GTK=CCMP]
Aug 24 18:33:50 OpenWrt daemon.warn dnsmasq-dhcp[2864]: DHCP packet received on m5 which has no address
Aug 25 01:33:50 OpenWrt kern.warn kernel: [142406.492702] 5g6zE9SRcY: STA be:b9:23:00:cf:50, VLAN1, Type 0
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: SAE: State Nothing → Nothing for peer be:b9:23:00:cf:50 (Init)
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: SAE: State Nothing → Committed for peer be:b9:23:00:cf:50 (Sent Commit)
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: SAE: State Committed → Confirmed for peer be:b9:23:00:cf:50 (Sent Confirm)
Aug 25 01:33:50 OpenWrt kern.warn kernel: [142406.559064] STA update be:b9:23:00:cf:50, VLAN1, Type -2
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: SAE: State Confirmed → Accepted for peer be:b9:23:00:cf:50 (Accept Confirm)
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 IEEE 802.11: associated (aid 1)
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=13 (5g6zE9SRcY) alg=0 addr=0x1275ed8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:50 OpenWrt kern.warn kernel: [142406.691768] br-lan: received packet on eth0 with own address as source address (addr:bc:b9:23:00:d3:8c, vlan:0, src:eth0)
Aug 25 01:33:50 OpenWrt kern.err kernel: [142406.691821] pkt:00000000: 00 01 08 00 06 04 00 01 bc b9 23 00 d3 8c c0 a8 …#…
Aug 25 01:33:50 OpenWrt kern.err kernel: [142406.692646] pkt:00000010: f1 6f ff ff ff ff ff ff c0 a8 f1 6f 00 00 00 00 .o…o…
Aug 25 01:33:50 OpenWrt kern.err kernel: [142406.693232] pkt:00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
Aug 25 01:33:50 OpenWrt daemon.err hostapd: no such r0 nor r1 for: be:b9:23:00:cf:50
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 WPA: sending 1/4 msg of 4-Way Handshake
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 WPA: received EAPOL-Key frame (2/4 Pairwise)
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: Assigned VLAN ID 0 from wpa_psk_file to be:b9:23:00:cf:50
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 WPA: sending 3/4 msg of 4-Way Handshake
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 WPA: received EAPOL-Key frame (4/4 Pairwise)
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=13 (5g6zE9SRcY) alg=3 addr=0x1275ed8 key_idx=0 set_tx=1 seq_len=0 key_len=16 key_flag=0x2c
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: AP-STA-CONNECTED be:b9:23:00:cf:50
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 RADIUS: starting accounting session 98D598F6744AEE09
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 WPA: pairwise key handshake completed (RSN)
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: EAPOL-4WAY-HS-COMPLETED be:b9:23:00:cf:50
Aug 25 01:33:50 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA be:b9:23:00:cf:50 IEEE 802.11: disassociated
Aug 25 01:33:50 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: AP-STA-DISCONNECTED be:b9:23:00:cf:50
Aug 25 01:33:50 OpenWrt user.alert : mesh w/no alta mac
Aug 25 01:33:50 OpenWrt user.notice root: netd: Loop found in mesh_start
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: CTRL-EVENT-CONNECTED - Connection to b6:f1:74:73:f5:bb completed [id=0 id_str=]
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: CTRL-EVENT-DISCONNECTED bssid=b6:f1:74:73:f5:bb reason=3 locally_generated=1
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: wpa_driver_nl80211_set_key: ifindex=5414 (m5) alg=0 addr=0 key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: wpa_driver_nl80211_set_key: ifindex=5414 (m5) alg=0 addr=0x1c050f0 key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: CTRL-EVENT-DSCP-POLICY clear_all
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: PMKSA-CACHE-REMOVED b6:7f:af:33:f5:bb 0
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: PMKSA-CACHE-REMOVED b6:f1:74:73:f5:bb 0
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: nl80211: deinit ifname=m5 disabled_11b_rates=0
Aug 25 01:33:50 OpenWrt kern.err kernel: [142407.145676] wlan: [12106:I:ANY] osif_vap_pre_stop_sta: Stopping STA vap
Aug 25 01:33:50 OpenWrt kern.err kernel: [142407.152472] wlan: [0:I:ANY] ieee80211_assoc_state_run_event: ieee80211_assoc_state_run_event: vap: 1(0x0b4f251d) event: 2
Aug 25 01:33:50 OpenWrt daemon.notice wpa_supplicant[12106]: m5: CTRL-EVENT-TERMINATING
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.175889] wlan: [12792:I:ANY] osif_nss_ol_vap_delete: vap detach 8e6c0c22: if_num 33
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.175935] wlan: [12792:I:ANY] osif_nss_vdev_detach: Dealloc Dynamic interface Node :33 of type:6
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.176749] wlan: [0:I:CMN_MLME] cm_handle_discon_req_in_non_connected_state: vdev 1 droping disconnect req from source 4 in INIT state
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.177183] wlan: [12792:E:CMN_MLME] cm_disconnect_start_req_sync: Disconnect failed with status 4
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.178697] wlan: [12792:I:ANY] [UNSPECIFIED] vap-1(m5):mlme_sta_swbmiss_timer_detach:disable bitmap is 0x2
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.178797] wlan: [12792:I:ANY] [UNSPECIFIED] vap-1(m5):mlme_sta_swbmiss_timer_detach:id 0 name (SCANNER) is still allocated
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.179671] wlan: [12792:I:ANY] [UNSPECIFIED] vap-1(m5):mlme_sta_swbmiss_timer_detach:id 1 name (tmp) is still allocated
Aug 25 01:33:51 OpenWrt kern.err kernel: [142408.180811] wlan: [12792:I:ANY] dp_lag_pdev_set_sta_vdev: dp_lag_pdev_set_sta_vdev pdev(2c060e8d) sta_vdev 00000000
Aug 25 01:33:51 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 IEEE 802.11: disassociated
Aug 25 01:33:51 OpenWrt daemon.notice hostapd: 2x8SaPBBf_: AP-STA-DISCONNECTED 40:f5:20:e1:bf:14
Aug 25 01:33:52 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=0 addr=0x21f8668 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:53 OpenWrt user.notice root: netd: Failed, failures: 1
Aug 25 01:33:54 OpenWrt kern.warn kernel: [142410.462478] wlan: kick 5g6zE9SRcY
Aug 25 01:33:54 OpenWrt kern.err kernel: [142410.945391] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported BCAST RATE is 6000(kbps) rate code: 0x10000003
Aug 25 01:33:54 OpenWrt kern.err kernel: [142410.945482] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported MCAST RATE 6000(kbps), rate code: 0x10000003
Aug 25 01:33:54 OpenWrt kern.err kernel: [142410.946289] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported BCAST RATE is 6000(kbps) rate code: 0x10000003
Aug 25 01:33:54 OpenWrt kern.err kernel: [142410.946931] wlan: [0:I:ANY] ol_ath_vap_set_param: Now supported MCAST RATE 6000(kbps), rate code: 0x10000003
Aug 25 01:33:54 OpenWrt daemon.info hostapd: 5g6zE9SRcY: IEEE 802.11 driver had channel switch: freq=5785, ht=1, vht_ch=0x0, he_ch=0x0, offset=1, width=3 (80 MHz), cf1=5775, cf2=0
Aug 25 01:33:54 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: CTRL-EVENT-CHANNEL-SWITCH freq=5785 ht_enabled=1 ch_offset=1 ch_width=80 MHz cf1=5775 cf2=0 dfs=0
Aug 25 01:33:54 OpenWrt user.notice root: netd: Failed, failures: 2
Aug 25 01:33:54 OpenWrt kern.warn kernel: [142411.345105] 2x8SaPBBf_: STA 40:f5:20:e1:bf:14, VLAN1, Type 0
Aug 25 01:33:54 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 IEEE 802.11: authenticated
Aug 25 01:33:54 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 IEEE 802.11: associated (aid 7)
Aug 25 01:33:54 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=0 addr=0x21f8668 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:55 OpenWrt daemon.err hostapd: no such r0 nor r1 for: 40:f5:20:e1:bf:14
Aug 25 01:33:55 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=0 addr=0x21f8668 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:55 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 WPA: sending 1/4 msg of 4-Way Handshake
Aug 25 01:33:55 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 WPA: received EAPOL-Key frame (2/4 Pairwise)
Aug 25 01:33:55 OpenWrt daemon.notice hostapd: Assigned VLAN ID 0 from wpa_psk_file to 40:f5:20:e1:bf:14
Aug 25 01:33:55 OpenWrt kern.warn kernel: [142411.489288] STA update 40:f5:20:e1:bf:14, VLAN1, Type 1
Aug 25 01:33:55 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 WPA: sending 3/4 msg of 4-Way Handshake
Aug 25 01:33:55 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 WPA: received EAPOL-Key frame (4/4 Pairwise)
Aug 25 01:33:55 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=3 addr=0x21f8668 key_idx=0 set_tx=1 seq_len=0 key_len=16 key_flag=0x2c
Aug 25 01:33:55 OpenWrt daemon.notice hostapd: 2x8SaPBBf_: AP-STA-CONNECTED 40:f5:20:e1:bf:14
Aug 25 01:33:55 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 RADIUS: starting accounting session C211F69426185124
Aug 25 01:33:55 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA 40:f5:20:e1:bf:14 WPA: pairwise key handshake completed (RSN)
Aug 25 01:33:55 OpenWrt daemon.notice hostapd: 2x8SaPBBf_: EAPOL-4WAY-HS-COMPLETED 40:f5:20:e1:bf:14
Aug 25 01:33:55 OpenWrt user.notice root: netd: Failed, failures: 3
Aug 25 01:33:56 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 IEEE 802.11: disassociated
Aug 25 01:33:56 OpenWrt daemon.notice hostapd: 2x8SaPBBf_: AP-STA-DISCONNECTED e0:98:06:ad:20:16
Aug 25 01:33:56 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=0 addr=0x21f8228 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:57 OpenWrt user.notice root: netd: Failed, failures: 4
Aug 25 01:33:58 OpenWrt user.notice root: netd: Failed, failures: 5
Aug 25 01:33:59 OpenWrt user.notice root: netd: Failed, failures: 6
Aug 25 01:33:59 OpenWrt kern.warn kernel: [142416.219921] 2x8SaPBBf_: STA e0:98:06:ad:20:16, VLAN1, Type 0
Aug 25 01:33:59 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 IEEE 802.11: authenticated
Aug 25 01:33:59 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 IEEE 802.11: associated (aid 4)
Aug 25 01:33:59 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=0 addr=0x21edca8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:33:59 OpenWrt daemon.err hostapd: no such r0 nor r1 for: e0:98:06:ad:20:16
Aug 25 01:33:59 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 WPA: sending 1/4 msg of 4-Way Handshake
Aug 25 01:34:00 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 WPA: received EAPOL-Key frame (2/4 Pairwise)
Aug 25 01:34:00 OpenWrt daemon.notice hostapd: Assigned VLAN ID 0 from wpa_psk_file to e0:98:06:ad:20:16
Aug 25 01:34:00 OpenWrt kern.warn kernel: [142416.439692] STA update e0:98:06:ad:20:16, VLAN1, Type 1
Aug 25 01:34:00 OpenWrt daemon.err hostapd: no such r0 nor r1 for: e0:98:06:ad:20:16
Aug 25 01:34:00 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 WPA: sending 3/4 msg of 4-Way Handshake
Aug 25 01:34:00 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 WPA: received EAPOL-Key frame (4/4 Pairwise)
Aug 25 01:34:00 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=12 (2x8SaPBBf_) alg=3 addr=0x21edca8 key_idx=0 set_tx=1 seq_len=0 key_len=16 key_flag=0x2c
Aug 25 01:34:00 OpenWrt daemon.notice hostapd: 2x8SaPBBf_: AP-STA-CONNECTED e0:98:06:ad:20:16
Aug 25 01:34:00 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 RADIUS: starting accounting session 5930CEBC228CC2CE
Aug 25 01:34:00 OpenWrt daemon.info hostapd: 2x8SaPBBf_: STA e0:98:06:ad:20:16 WPA: pairwise key handshake completed (RSN)
Aug 25 01:34:00 OpenWrt daemon.notice hostapd: 2x8SaPBBf_: EAPOL-4WAY-HS-COMPLETED e0:98:06:ad:20:16
Aug 25 01:34:00 OpenWrt user.notice root: netd: Failed, failures: 7
Aug 25 01:34:01 OpenWrt user.notice root: netd: Failed, failures: 8
Aug 25 01:34:01 OpenWrt kern.warn kernel: [142418.275698] 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd, VLAN1, Type 0
Aug 25 01:34:01 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd IEEE 802.11: authenticated
Aug 25 01:34:01 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd IEEE 802.11: associated (aid 1)
Aug 25 01:34:01 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=13 (5g6zE9SRcY) alg=0 addr=0x1274be8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=13 (5g6zE9SRcY) alg=0 addr=0x1274be8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:34:02 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd WPA: sending 1/4 msg of 4-Way Handshake
Aug 25 01:34:02 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd WPA: received EAPOL-Key frame (2/4 Pairwise)
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: Assigned VLAN ID 0 from wpa_psk_file to 8e:e5:96:9a:5e:cd
Aug 25 01:34:02 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd WPA: sending 3/4 msg of 4-Way Handshake
Aug 25 01:34:02 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd WPA: received EAPOL-Key frame (4/4 Pairwise)
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=13 (5g6zE9SRcY) alg=3 addr=0x1274be8 key_idx=0 set_tx=1 seq_len=0 key_len=16 key_flag=0x2c
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: AP-STA-CONNECTED 8e:e5:96:9a:5e:cd
Aug 25 01:34:02 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd RADIUS: starting accounting session 2CDB79DCE304846E
Aug 25 01:34:02 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd WPA: pairwise key handshake completed (RSN)
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: EAPOL-4WAY-HS-COMPLETED 8e:e5:96:9a:5e:cd
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: FT: RRB-OUI type 3 send to bc:b9:23:00:cf:50 (len=274, iface=br-lan)
Aug 25 01:34:02 OpenWrt daemon.notice hostapd: FT: RRB-OUI type 3 send to bc:b9:23:00:e1:18 (len=274, iface=br-lan)
Aug 25 01:34:02 OpenWrt user.notice root: netd: Failed, failures: 9
Aug 25 01:34:04 OpenWrt user.notice root: netd: Failed, failures: 10
Aug 25 01:34:04 OpenWrt user.notice root: netd: cloudflare ret: 0
Aug 25 01:34:05 OpenWrt user.notice root: netd: Next state: mesh_normal
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.066125] wlan: [13730:I:MBSSIE] osif_mbssid_sanity_check: mbssid_sanity_ok: YES
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.066172] wlan: [13730:I:ANY] osifp_create_wlan_vap: VDEV Create be:b9:23:00:d3:8c
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.066768] wlan: [13730:I:ANY] wlan_vap_create: devhandle=0x14b246f5, opmode=IEEE80211_M_STA, flags=0x1
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.070271] wlan: [13730:I:ANY] ol_ath_vap_set_param: Setting SGI value: 1
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.070684] wlan: [13730:I:ANY] ol_ath_vap_set_param: VDEV params:HE su_bfee:1|su_bfer:1|mu_bfee:0|mu_bfer:0|dl_muofdma:0|ul_muofdma:0|ul_mumimo:1|dl_muofdma_bfer:0|disable_mu_mimo: 0
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.070767] wlan: [13730:I:ANY] ol_ath_vap_set_param: he_bf_cap=0x43
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.072114] wlan: [13730:I:ANY] ol_ath_vap_set_param: VDEV params: AC/VHT sounding mode:HE|SU/MU sounding mode:SU|Trig/Non-Trig sounding mode:Non-Trigged
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.072996] wlan: [13730:I:ANY] osif_nss_ol_vap_create: NSS wifi offload VAP create IF 34 nss_id -1
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.073589] wlan: [13730:I:ANY] osif_nss_ol_vap_create: NSS radio_if 29
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.074877] wlan: [0:I:ANY] osif_nss_vdev_cfg_callback: VDEV configuration success: 0
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.074965] wlan: [13730:I:ANY] osif_nss_ol_vap_create: vap create c28bdf0d : if_num 34
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.076675] wlan: [13730:I:ANY] dp_lag_pdev_set_sta_vdev: dp_lag_pdev_set_sta_vdev pdev(2c060e8d) sta_vdev 3166b4a3
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.076765] wlan: [13730:I:ANY] ol_ath_set_pn_mgmt_rxfilter: PN RxFilter set to 0
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.077470] wlan: [13730:E:ANY] wlan_create_attach_vdev_rawsim_ctxt: simulation module not registerd
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.078252] wlan: [13730:I:ANY] osif_create_vap_complete: TX Checksum:1|SG:1|TSO:1|LRO:0
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.079257] wlan: [13730:I:ANY] WLAN-NSS: VAP NSS ops initialized
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.079771] wlan: [13730:I:RPTR] RPTR vdev flags:0 pdev flags:0 vdev_id:1 pdev_id:0
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.079836] wlan: [13730:I:ANY] dp_lag_pdev_set_sta_vdev: dp_lag_pdev_set_sta_vdev pdev(2c060e8d) sta_vdev 3166b4a3
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.085234] wlan: [13730:I:ANY] VAP device m5 created osifp: (c28bdf0d) os_if: (0b4f251d)
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.086199] wlan: [0:I:RPTR] RPTR Same ssid disable:1
Aug 25 01:34:05 OpenWrt kern.info kernel: [142422.141674] m5: Caught tx_queue_len zero misconfig
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: Successfully initialized wpa_supplicant
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: rfkill: Cannot open RFKILL control device
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: wpa_driver_nl80211_set_key: ifindex=5415 (m5) alg=0 addr=0 key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: wpa_driver_nl80211_set_key: ifindex=5415 (m5) alg=0 addr=0 key_idx=1 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: wpa_driver_nl80211_set_key: ifindex=5415 (m5) alg=0 addr=0 key_idx=2 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: wpa_driver_nl80211_set_key: ifindex=5415 (m5) alg=0 addr=0 key_idx=3 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: wpa_driver_nl80211_set_key: ifindex=5415 (m5) alg=0 addr=0 key_idx=4 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: wpa_driver_nl80211_set_key: ifindex=5415 (m5) alg=0 addr=0 key_idx=5 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
Aug 25 01:34:05 OpenWrt daemon.err wpa_supplicant[13764]: nl80211: kernel reports: unexpected nested data
Aug 25 01:34:05 OpenWrt daemon.err wpa_supplicant[13764]: nl80211: Set scan default IEs failed: ret=-22 (Invalid argument)
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: nl80211: eapol_1905_init
Aug 25 01:34:05 OpenWrt daemon.notice wpa_supplicant[13764]: nl80211: eapol_1905_init done
Aug 25 01:34:05 OpenWrt daemon.info hostapd: 5g6zE9SRcY: STA 8e:e5:96:9a:5e:cd IEEE 802.11: disassociated
Aug 25 01:34:05 OpenWrt daemon.notice hostapd: 5g6zE9SRcY: AP-STA-DISCONNECTED 8e:e5:96:9a:5e:cd
Aug 25 01:34:05 OpenWrt daemon.notice hostapd: wpa_driver_nl80211_set_key: ifindex=13 (5g6zE9SRcY) alg=0 addr=0x1274be8 key_idx=0 set_tx=1 seq_len=0 key_len=0 key_flag=0x20
Aug 25 01:34:05 OpenWrt kern.warn kernel: [142422.198609] __nss_qdisc_init[2192]:NSS qdisc 9717c800 (type 1) used along with non-nss qdiscs, or the interface is currently down
Aug 25 01:34:05 OpenWrt kern.err kernel: [142422.398380] wlan: [0:I:CMN_MLME] PSOC_1 VDEV_0 Sending bcast deauth and DELETE_ALL_PEER, clients: 2
Aug 25 01:34:06 OpenWrt daemon.notice hostapd: our hops=1
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: Full candidate list:
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: fa:0d:ac:e0:ae:cb f=5240 snr=20 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: b6:f1:74:73:f5:bb f=5180 snr=26 hops=1
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: b6:7f:af:33:f5:bb f=5180 snr=26 hops=1
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: ce:94:35:0f:17:95 f=5220 snr=10 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: c0:94:35:0f:17:95 f=5220 snr=10 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: d2:94:35:0f:17:95 f=5220 snr=9 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: f4:17:b8:a1:84:6e f=5785 snr=11 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: 8a:17:b8:a1:84:6f f=5785 snr=10 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: e2:db:d1:30:9f:b7 f=5220 snr=7 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: 3e:00:f1:e2:12:fa f=5785 snr=7 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: 86:96:4e:38:2f:b3 f=5240 snr=5 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: f8:63:d9:49:33:63 f=5785 snr=4 hops=0
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: e6:63:d9
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: Short-list:
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: b6:f1:74:73:f5:bb(Cole-Office-5GHz) f=5180 snr=26 hops=1
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: b6:7f:af:33:f5:bb() f=5180 snr=26 hops=1
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: b6:7f:af:33:f5:bb(Cole-Office-5GHz) f=5180 snr=26 hops=1
Aug 25 01:34:08 OpenWrt daemon.notice wpa_supplicant[13776]: m5: Trying to associate with b6:f1:74:73:f5:bb (SSID=‘Cole-Office-5GHz’ freq=5180 MHz)
Aug 25 01:34:08 OpenWrt daemon.warn wpa_supplicant[13776]: FT: Invalid key management type (1024)
Aug 25 01:34:08 OpenWrt kern.err kernel: [142424.913615] wlan: [13776:I:ANY] wlan_cfg80211_connect: m5: DES SSID SET=“Cole-Office-5GHz”
Aug 25 01:34:08 OpenWrt kern.err kernel: [142424.913657] wlan: [13776:I:ANY] wlan_cfg80211_connect: DES BSSID SET=b6:f1:74:73:f5:bb
Aug 25 01:34:08 OpenWrt kern.err kernel: [142424.927905] wlan: [0:I:ANY] [NODE] vap-1(m5):ieee80211_setup_node forcing sta to associate in 30 mode
Aug 25 01:34:08 OpenWrt kern.err kernel: [142424.933651] wlan: [0:I:CMN_MLME] vdev 1 cm_id 0xc00001: Connecting to Cole-Office-5GHz b6:f1:74:73:f5:bb rssi: -66 freq: 5180 akm 0x0 cipher: uc 0x0 mc 0x0, wps 0 osen 0 force RSN 1 CC:
Aug 25 01:34:08 OpenWrt kern.err kernel: [142424.950007] wlan: [0:I:ANY] wlan_scan_update_channel_list: num_chan: 25
Aug 25 01:34:09 OpenWrt user.alert : mesh w/no alta mac
Aug 25 01:34:09 OpenWrt kern.warn kernel: [142426.062309] wlan: kick 5g6zE9SRcY
Aug 25 01:34:09 OpenWrt kern.err kernel: [142426.062643] wlan: [1413:E:mlme] mlme_cmd_abort: Active cmd not found type:29
Aug 25 01:34:10 OpenWrt user.alert : mesh w/no alta mac
Aug 25 01:34:11 OpenWrt user.alert : mesh w/no alta mac
Aug 25 01:34:12 OpenWrt daemon.notice wpa_supplicant[13776]: m5: CTRL-EVENT-ASSOC-REJECT bssid=b6:f1:74:73:f5:bb status_code=1
Aug 25 01:34:12 OpenWrt daemon.notice wpa_supplicant[13776]: BSSID b6:f1:74:73:f5:bb ignore list count incremented to 2, ignoring for 10 seconds
Aug 25 01:34:12 OpenWrt kern.err kernel: [142428.495093] wlan: [2882:I:ANY] [UNSPECIFIED] vap-1(m5):osif_vap_xmit_queue: wbuf xmit failed
Aug 25 01:34:12 OpenWrt daemon.notice wpa_supplicant[13776]: Full candidate list:
Aug 25 01:34:12 OpenWrt daemon.notice wpa_supplicant[13776]: fa:0d:ac:e0:ae:cb f=5240 snr=20 hops=0
Aug 25 01:34:12 OpenWrt daemon.notice wpa_supplicant[13776]: b6:7f:af:33:f5:bb f=5180 snr=26 hops=1
Aug 25 01:34:12 OpenWrt daemon.notice wpa_supplicant[13776]: b6:f1:74:73:f5:bb f=5180 snr=26 hops=1
@macnmod The colors at the top have been resolved to avoid red completely.
Also, I have a test firmware I can install if you would like to invite me to your site, for the flapping issue.
For sure. Not sure how to do so, but willing.
