I have some questions about the support for tailscale and netbird
tailscale EXIT node suvives to reboot?
is there a button to update the tailscale version? (or shall we wait for the router firmware to be updated? gl.inet routers use a reduced size version of tailscale, however with the remotetohome plugin it is very easy to update just tailscale
netbird EXIT node is supported?
netbird exit node survives to reboot?
how can be updated the netbird version? for this aspect there is no other router on the market with this feature as far as I know
zerotier exit node support is under development?
