My Mini Alta Rack
Here is my “finished” mini rack for my home. I had a 27u rack, but after moving away from a Savant control system and a whole home audio setup, my rack was empty. This gave me an idea to see what I could put together with the Rackmate T1 mini rack. I didn’t fit everything I wanted, and I would definitely want more purpose made accessories, but I think it turned out great. There are three auxiliary switches throughout the house, which I will eventually convert to Alta.
Equipment:
Netgear Modem (will be changing to a newer model)
GLI Router (will be changing out to the new Alta router)
Alta PoE 8 x2
Lutron and Ikea Hubs
Mac Mini
Overall, I think it came out well. I wish there was a good power solution that fits this rack and had IP control, I’m sure I’ll figure something out. I’m anxiously awaiting the new Alta router to round it all out.
Any questions I can answer, I’ll do my best.
This is awesome! Super clean!
Thanks! Just waiting on the router. :slight_smile:
:laughing: “finished”. If I’m not mistaken, that bottom unit is a Mac Mini? Homelab? Yeah, that’s never “finished” :rofl: :rofl:
Never finished. The Mac Mini is a Proxmox machine so I can self host or test certain software. Its main purpose is for Homebridge or Scrypted for now. I might upgrade to a newer Mac Mini, but we will see how slow this one is. I’m also waiting for the Route10, which will change how I wire some things. :slight_smile:
I was in the midst of installing a VM to test switching my internal DNS stack over and decided to pop over to our community and do some work instead of watching a progress bar roll across the screen so the timing was :pinched_fingers:t2:
Probably time better spent. :wink:
Insane cable management, it’s a very nice setup! More and more people are moving from the full-size rack (~20U) to something smaller. With the power of Nuc mini pcs, small switches, and the speed that AP provides, we can move from wired to wireless a little bit more and it is movable vs full size rack and it take less space :slight_smile:
Very nice sharing :clap:
Super clean and sexy!
Where is the new Route10 in that setup ??? :eyes: :fire:
My order has been in since it was announced. :frowning:
Can’t wait to see it in your mini rack when you will receive it!
unreal dude!!! this is exactly what im after for my home lab. tell me, can you actually buy units that i can bolt to this? be nice if alta done a 10" rack mount poe switch and patch panel that would tie in lovely with the rest of the alta gear i plan on using.
