Hi everyone,
I have a critical issue with 3 or 4 of my Alta Labs AP6-Pro access points installed at different locations. They have all completely died and exhibit the exact same symptoms.
The APs show absolutely no signs of life (no LED on the Alta logo). When plugged into a PoE switch, the switch port LED just flashes continuously (indicating a power delivery or load issue), but the AP refuses to boot or draw proper power. This started happening recently, in some cases right after a power cycle or reboot.
Thank you in advance for your help!
