Multi Wan support
Good day everyone, I recently bought a route 10 kit, I have more than one ISPs and many Lan Networks, some of the Lan networks need to connect to a specific Wan. How can I achieve this?
I don’t have multiple WAN myself so haven’t tried it really, but I believe there is only load balancing or failover available for multi-WAN via the UI, so far at least:
https://help.alta.inc/hc/en-us/articles/36027545057307-Load-Balancing
https://help.alta.inc/hc/en-us/articles/33052444521499-WAN-Failover
Anyone else who has got hands on experience?
Probably needs Policy Based Routing (PBR), which I think official support is being worked on right now. Although I believe there’s a couple scripts that have been posted in the forum to get things working from the CLI. I’ll have to see if I have a couple of those threads bookmarked :slight_smile:
I see they added policy based routing option in route 10, what the correct way to enable this? i need to forward specific network traffic to specific Wans, as well as port forwarding rules
To make port forwards apply to a specific WAN, fill in its ethX interface in “interface in”. If that’s not specified, it applies to all WANs.
PBR is pretty self-explanatory. Add rules there for traffic you want to take a path other than the default failover/load balancing. Specify the source network, and choose the WAN you want it to egress. We’ll have a KB article coming soon with details, but it should be easy to add the rules you need for that. Just remember first matching rule wins, and order them accordingly.
