@Alta-MattH also replied he’s in the talks with @Alta-MikeD , they are discussing internally what the issue could be. These guys are awesome to work with and great help!
With some sort of voodoo magic it’s working. Mike mentioned switching all AP’s to only my mesh test network. That seemed to have kicked them place, but then I set colors for each SSID and assigned all 3 to the APs. It still stayed connected at fast speeds so I deleted the mesh test SSID and all is still good. Before it also wasn’t accepting devices to connect to it unless I manually pushed them over, now it is:
Each SSID I gave it’s own colors even though I tried that earlier:
Thanks for helping us troubleshoot and good idea @Alta-MikeD !
I wonder if the ability to change the MTU would help? 1500 can be troublesome. 1400 might be a sweet spot. ![]()
I’m having this exact same issue with meshing. Plugged into network 300-400mbps, meshed 20mbps. Don’t know what else to do, tried different bands, different SSIDs, I can’t figure out
