It would be really handy to be able to toggle last known configuration and network map in the dashboard. When devices are offline you can’t see the configuration which makes troubleshooting remote networks really painful. It would save a ton of time if you could see the port comments/configuration, and network map as it was last known to be. Or if a device is offline, show the config and just have a label on the config window to the effect of “last known configuration” vs “active configuration”.
As a related ask, pre-provisioning, which might already be requested elsewhere but I haven’t seen it. Ability to pre-load devices by Mac or serial so more “ztp-like”.
