Map View in Route 10
Is there a way to turn this horizontal? I currently have 35 devices and it does not fit on the screen in vertical mode even if you shrink it. Maybe this can be added to Feature Request.
I assume you mean like top-down or bottom-up map. Not to my knowledge.
In terms of flipping it horizontally on a mobile device, yes for tilting the screen. However, having it that way is almost useless, at least on my Android device (OnePlus 10 Pro) as there is not much left for the actual map due to menus, etc. And, the orientation of the map stays the same, i.e. Route10 on the left and downstream devices on the right.
Vertical:
vs. Horizontal:
The map is better suited for a proper computer browser and screen :slightly_smiling_face:
