Not a big issues but just wanted to report an incorrect topology. Not sure if this is because its a non Alta switch. Layout is Cable Modem via ethernet to port 1 on Route10. I then have the 48 port switch connected via SFP 2 on the Route 10.
yeah I’m running into the same issue
I’ve got a Route10 connected to a PoE 8 port connected to an edgeswitch (with LLDP enabled in the console), and the device map still shows the devices connected to the edgeswitch at entirely different places from reality, and nothing “below” the edgeswitch
would be great if the LLDP protocol is supported to add devices to the map in the right depth of the graph, that someone could tell us what needs to be setup to allow for it
This thread is a bit old and may have been addressed already by some new updates. Could you post your issue as a new thread that we could address separately?
No, it was NOT addressed. I am having the same mapping issue.
Could you create a new thread?
