Howdy,
I have a route10 and then an alta switch and in the switch I have 3 alta APs and and a small ubiquity switch (hoping to get rid of that some day).
On the map I can see that the router has like 15 other client devices that is not connected directly to it. they are connected to the alta switch…
another thing I can see connection to my ISP showing up as a connection inbound it should be on the left side of the router to show it more properly…
