Major issues with multiple AP6 Pros after 3.0p to 3.0q
We migrated our Wi-Fi from Ubiquiti a little over a year ago, and everything has been working great until recently. We still use Ubiquiti for our router and most of our switches, but none of our Wi-Fi equipment is Ubiquiti anymore.
Ever since the latest firmware update, our APs have been behaving very strangely. They randomly stop communicating and show as disconnected, seemingly for no reason.
We have already tried the Reset on Power recovery procedure, which booted the AP into failsafe mode, downloaded the latest firmware, and allowed us to set it up again through the app. Unfortunately, the same issue continues even after going through that entire process.
The behavior is completely random. Some APs will run perfectly fine for 12+ hours before suddenly disconnecting, while others might only stay connected for 4 hours before doing the same thing.
We’ve tried just about everything we can think of, including manually configuring the Wi-Fi channels on both the 2.4 GHz and 5 GHz bands, but nothing seems to make a difference.
At this point, we’re running out of ideas. The system was stable for over a year, and these problems only started after the latest update, so we’re strongly suspecting a firmware-related issue.
Would it be possible for someone from the support team to remotely connect, review the configuration and logs, and help us figure out what’s going on? We’d really appreciate some assistance getting everything stable again.
Hello Sly,
Yes, we’d be happy to take a look!
Please reach out to us at support@alta.inc so we can better assist you with the issue.
Thank you!
I have the exact same problem since 27 Oct 2026. Will an update be released to fix the problem or is there some guidance on how to re-configure the AP?
An update was released.
My AP units are updated to 3.0r but in the last 20 mins I had a connection drop. What should I check?
I, too, am having wireless clients dropping. I noticed it today when my Pi Zero 2 W running DAKboard showed disconnected, and my LG Signage TV connected to a DAKboard link also showed disconnected.
I’ve also had TVs continually needing to have the WiFi manually turned off and on to regain connectivity.
Appears very similar to my issue here: AP6-Pro - Throughput + Packet Loss issues
Seems to be resolved with 3.0r
@michaelmurfy that’s the version we’re having the issue in. @Alta-Jeff would you mind taking a look at my site to see if anything might be contributing to this following the upgrade? Also, could you or someone else assist me with rolling back to an earlier version?
Same here. AP6 Pro on 3.0r, local Control.
The AP randomly stops passing internet traffic and only works again after a reboot. Power cycling just the AP fixes it for a while, so the fault looks like the AP itself, not the router or the uplink.
@assistant.gbcsj We’re not seeing anything like that anywhere, so can you invite me to your site please?
Hi Jeff, thanks. I would rather not give access to my site, and I am on the local controller anyway. Happy to help any other way I can. It is not just me either, several others in this thread have the same issue since the 3.0p update. Is there a way I can roll back to 2.4o myself?
We’ve already worked directly with several users, and have found some issues with their sites, but nothing that is problematic with the software in 3.0r specifically. I’m happy to help, but I’ll need access to your site in order to see if there’s anything going on.
Hi Jeff, fair. Could you tell me what issues you found on the other sites, so I can check mine? I am not keen on giving anyone access to my network. Keeping it locked down is honestly a big reason I picked Alta.
Sure, I will DM you with some information; I doubt that you are experiencing the same problems, but there’s always a possibility.
