1 macbook on my network lost connection and when you tried to connect it would say the network couldn’t be found. Forgot the network and tried again it would connect and then just ask for the password over and over. This was fixed by restarting all my APs? Any idea what happened? Was the only device on the network to seem to be affected.
I have had this on my Macbook Pro a few times in the past on a variety of different APs - think it’s more an apple issue than an Alta one.
This ^
Happened to me but MacOS Sequoia seems better tbh.
I just installed 2 AP 6 PRO units indoors and 2 AP 6 PRO outdoor units outside.
I ahem a MACBOOK PRO running Sequoia 15.0.1 (24A348) - Mine seems to be really good.
My wife has a MacBook Air running Sequoia 15.0.1 (24A348) and it really does not get a good connection at all and she is right near the AP unit. it goes from weak single to half ok signal all day.
When we had UNIFI units that was a whole different topic of hell with MAC Apple products.
