Lost sites how to recover
I just wanted to check is there anyway to recover sites , I lost a couple of sites I had on my account
Do I need to call to site to re add or is there a way to recover sites
You may need to reach out to support at support@alta.inc to get help reconnecting sites to your account(s).
Regardless, I will ask a couple questions:
  • Are the unlisted sites still functioning as expected?
  • Are you sure that you didn’t create those using some other email address? This is the most common issue in these types of situations.
