Local controller solid turquoise
My local controller turned solid turquoise, does anyone know what this indicates?
Thanks
Usually that only happens while it is downloading the latest firmware. Here is some references on the light colors
Thanks for the reply but it’s been turquoise all day. Going to assume something is not right based on the LED pattern information. Will let it sit for the night!
Did you set the LED color to something else? I’m noticing setting the color on my Switch 8 sometimes gets the color wrong.
Firmware 2.1p
“Sometimes gets the color wrong” lol…I really appreciate you making that comment. I should have tried that, I changed the color to red then back to white and now it’s white. Guess that might be a little bug!
I appreciate all the comments.
Clearly this is a bug. With the controller led color set to white, the controller continues to revert back to turquoise after route10 reboots.
