Local Controller (Docker) Upgrade
Hey everyone!
First and foremost, I am in LOVE with the self-hosted controller. Great work guys.
I do see some controller updates (1.0f specifically) and was wondering how I would update my docker image for it? DockerHub only shows 1.0d and my box cant see anything but 1.0d.
Does anyone have any suggestions? Is it not possible in the Docker version?
Welcome Lewty!
Tom Hanks Hello GIF
Iā€™m sure the Alta team will love your positive comment :slight_smile:
I see what you mean, @Alta-Chase are you guys publishing the latest version to docker hub?
Thanks for the positive feedback @lewty1987 ! Love to hear it!
@WhyAydan Thanks for the tag. As long as the self hosted version is is on 1.0d, you can trigger an update from inside of the Self Hosted controller. Browse to Settings ā†’ System ā†’ General
From there, you can kick off the update. Please let us know how it goes!
@Alta-Chase 1,2,3ā€¦ and we are updated! Thank you @WhyAydan for getting the ball rolling.
Really, again, I cant thank Alta enough for broadening my horizons with great gear. Coming from a once Unifi fanboy. :slight_smile:
@lewty1987 Glad you are with us - 100%! Just going to get better and better from here!
Happy to help :slight_smile:
That it will! Looking forward to it, to say the least!
