So I’ve been testing out the local controller, and I keep getting the issue when adding a new device. I click setup and then it just says disconnected, the only way I have found to get it to connect is to go to the IP of the device and paste in the url of the local controller.
@dalewhlrr Thanks for the post/question. Just a quick check on the basics. Is the AP and Controller on the same VLAN and subnet?
Yes, all my network hardware is on the same vlan at the moment, it finds the new devices but gets stuck on disconnect.
@dalewhlrr Fantastic! Next, can you browse to settings->system->general and make sure you are on 1.0f? If not, will you update and then see if the issue persists?
Ok it’s updated now, I don’t know why I didn’t see that update earlier, I will try to add a new device tomorrow to see if that fixes the issue. Thanks for the assistance.
@dalewhlrr You bet! Thanks for working with our gear!
