LAG/Aggregate - Alta Switching
So I have searched around a bit and I’m not seeing anything on this, but I am not seeing options for a LAG or an Aggregate setup on any of the interfaces or the switch itself. Am i missing it or is this something that isnt available at this time?
Current only static LAG is supported. LACP is coming in a future firmware update. You change this in port settings. The first dropdown you see is “mode”. LAG is at the bottom of the list under mode.
LACP just recently released in switch firmware version 2.1q and improved 2.1r.
