Hello all you fine folks!
I am setting up an Alta labs - lab environment, currently I have an AP6 (not pro) and have a 16 port switch coming in so I can have a test environment. I plan to test the stand alone controller in this setup.
My main question, would there be significant gain if I were to have an AP6-Pro as well, or instead of the standard AP6? Also, what, if anything else should I consider having in order to test scenarios for implementations?
And, is there a way to virtualize any of the Alta bits (other than the controller)? I know it would be hard to virtualize an AP, but switches maybe? Anyway, if anyone has any input on this, feel free to sound off.
Thanks!
