Can I get some help with a firewall rule to block a guest network from being able to SSH into Route10? I created a rule with TCP / UDP protocols, source as the guest subnet, destination IP as the gateway address for the guest subnet, and destination port as 22. Zone in and out are both set to LAN. However, it does not block SSH when I test from the guest subnet.
Try setting Zone Out to None. None should be used to match traffic that is destined for the Route10 itself, rather than traffic that is just passing through the Route10.
Thank you sir! As usual I’ll give it a try when I get home today.
Hi @Alta-Mark. Unfortunately that change did not seem to make a difference. I have port 80, 443, and 22 blocked, and I am still able to get to Rout10 over all 3 ports. What else might I try?
Hi @Alta-Mark I actually just figured it out. Your change was necessary and ultimately was the fix. I also had to turn off “Isolation” for that VLAN. I forgot that when you use “Isolation”, no other firewall rules can apply to that VLAN.
Thank you for the help!
