Issue with Route 10 after recent updates
Started 3 updates ago. When the update installs and reboots the router, the reboot is not clean. I use Port 2 as my WAN port since it has POE and my ONT requires POE and I didn’t want yet another plug.
If I unplug the ethernet cable from Port 2 and wait 60 seconds while I reboot the router with no cable everything runs great. Bit of an issue if I’m away from home.
Best way to diagnose this?
What sort of WAN connection do you have? Pppoe? Vlans dhcp?
I’ve had similar issues which appear to have been resolved, but needed support to access router to diagnose
I have planet.net straight forward DHCP without lan tagging.
Just an update to this. I do not have to reboot the router. All I did last night was unplug the cable to the ONT and wait a bit.
try to set the speed on the port see if that makes any different. i had similar problem in the past but it was on the SFP port.
Did an experiment this morning. I set POE for port 2 to be always on. Pinned port to 2.5 mbps. Rebooted router.
NO GOOD. Still boots up with WAN not providing POE to the ONT. Thoughts?
Once the router reboots there is no activity on Port 2. All that is lit is the little light below the port showing that it is POE capable. It isn’t yellow though, it’s red. The ISP thinks it’s an issue with the ONT and has replaced it. I’m waiting for a time to test again, but for now, with the inline injector and using port 1 I’m at least running reliably. Even after a reboot.
