Has anyone had any luck getting IPv6 working with telus?
I have it set to DHCP and PD size of 56 which I read it should be (but 64 or blank makes no difference.)
Has anyone else had any luck? Is there anything else I can try?
My output of cat /etc/config/network:
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config device
option name 'eth3'
option mtu '1500'
config interface 'wan'
option ifname 'eth3'
option metric '200'
option dns_metric '200'
option proto 'dhcp'
option norelease '1'
option ipaddr '##.##.##.##'
option peerdns '0'
option dns '1.1.1.1 1.0.0.1 2606:4700:4700::1111 2606:4700:4700::1001'
option reqprefix '56'
config interface 'wan6'
option proto 'dhcpv6'
option peerdns '0'
config device
option name 'br-lan'
option type 'bridge'
option mtu '1500'
option stp '0'
option igmp_snooping '0'
option ports 'eth2 eth1 eth0 eth5'
option macaddr 'bc:b9:23:81:##:##'
config interface 'lan'
option ifname 'br-lan'
option ipaddr '192.168.86.1/23'
list ip6class 'wan6'
option ip6assign '64'
option multicast_querier '0'
option force_link '1'
config interface 'vpn0'
option ifname 'ppp0'
option proto 'none'
option auto '1'
config interface 'vpn1'
option ifname 'ppp1'
option proto 'none'
option auto '1'
config interface 'vpn2'
option ifname 'ppp2'
option proto 'none'
option auto '1'
config interface 'vpn3'
option ifname 'ppp3'
option proto 'none'
option auto '1'
config interface 'vpn4'
option ifname 'ppp4'
option proto 'none'
option auto '1'
config interface 'vpn5'
option ifname 'ppp5'
option proto 'none'
option auto '1'
config interface 'vpn6'
option ifname 'ppp6'
option proto 'none'
option auto '1'
config interface 'vpn7'
option ifname 'ppp7'
option proto 'none'
option auto '1'
config interface 'vpn8'
option ifname 'ppp8'
option proto 'none'
option auto '1'
config interface 'vpn9'
option ifname 'ppp9'
option proto 'none'
option auto '1'
config interface 'vpn10'
option ifname 'ppp10'
option proto 'none'
option auto '1'
config interface 'vpn11'
option ifname 'ppp11'
option proto 'none'
option auto '1'
config interface 'vpn12'
option ifname 'ppp12'
option proto 'none'
option auto '1'
config interface 'vpn13'
option ifname 'ppp13'
option proto 'none'
option auto '1'
config interface 'vpn14'
option ifname 'ppp14'
option proto 'none'
option auto '1'
config interface 'vpn15'
option ifname 'ppp15'
option proto 'none'
option auto '1'
ifstatus wan6
"up": false,
"pending": true,
"available": true,
"autostart": true,
"dynamic": false,
"proto": "dhcpv6",
"device": "eth3",
"data": {
Edit 3:
ifconfig
br-lan Link encap:Ethernet HWaddr BC:B9:23:81:##:14##
inet addr:192.168.86.1 Bcast:192.168.87.255 Mask:255.255.254.0
inet6 addr: fe80::beb9:23ff:fe81:2514/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:155611577 errors:0 dropped:0 overruns:0 frame:0
TX packets:617768647 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:39957707158 (37.2 GiB) TX bytes:1054382576431 (981.9 GiB)
eth0 Link encap:Ethernet HWaddr BC:B9:23:81:##:##
RX packets:238933971 errors:0 dropped:0 overruns:0 frame:0
TX packets:870322275 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:64278373470 (59.8 GiB) TX bytes:1179516869695 (1.0 TiB)
eth1 Link encap:Ethernet HWaddr BE:B9:23:82:##:##
RX packets:8421644 errors:0 dropped:0 overruns:0 frame:0
TX packets:23040117 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3047171979 (2.8 GiB) TX bytes:23991225231 (22.3 GiB)
Base address:0x4000
eth2 Link encap:Ethernet HWaddr BE:B9:23:83:##:##
RX packets:18585228 errors:5 dropped:8677 overruns:0 frame:5
TX packets:98942297 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4526380389 (4.2 GiB) TX bytes:108253786463 (100.8 GiB)
Base address:0x8000
eth3 Link encap:Ethernet HWaddr BC:B9:23:81:##:##
inet addr:75.156.107.27 Bcast:75.156.107.255 Mask:255.255.252.0
inet6 addr: fe80::beb9:23ff:fe81:2515/64 Scope:Link
RX packets:981215730 errors:0 dropped:0 overruns:0 frame:0
TX packets:255918780 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1307193858567 (1.1 TiB) TX bytes:67456386142 (62.8 GiB)
Base address:0xc000
eth5 Link encap:Ethernet HWaddr BE:B9:23:84:##:##
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Base address:0x4000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:482676 errors:0 dropped:0 overruns:0 frame:0
TX packets:482676 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:55046437 (52.4 MiB) TX bytes:55046437 (52.4 MiB)
Hmm ifconfig shows some devices with ipv6 possibly, some just are missing? But are those just local ipv6? Edit: Yes fe80 is local.
