IPS improvements
Great work on adding Block Duration — it’s a very welcome improvement! When Block Duration is set, and rules/signatures triggers, they clearly end up in iptables drop rules, and for example consecutive curl calls to testmyids.org end up hanging there. Great! :flexed_biceps:
Here are a few suggestions that could further enhance usability and performance:
  1. Rule comments
    Add optional comments to IPS-inserted iptables rules (e.g., signature ID info) for easier troubleshooting.
  2. Use ipset for blocklists
    Replace per-flow iptables rule pairs with ipset-based blocking for better performance and scalability.
  3. Include signature info in logs
    When adding/removing IPS blocks, include signature ID/severity in /var/log/messages.
  4. Clarify bidirectional blocking
    Add a short tooltip explaining that IPS blocks both directions by default.
  5. Configurable block direction & action
    Allow choosing unidirectional vs bidirectional blocking, and drop vs reject. Ideally also per-signature and/or per-severity.
  6. Ignored-rule management
    Provide a page to view/reset ignored rules without clearing all IPS state.
  7. Add IDS/IPS status counters, a few ideas:
    • Total alerts & alerts by severity
    • Number of Current blocked IP pairs & active ignored rules
    • Top talkers/destinations triggering alerts
    • IPS drops per minute & conntrack deletions
    • Most-triggered signatures (noise detectors)
Yes! Definitely a good list of improvements to chew on :smiley:
