Inter VLAN routing
Hey folks, I have a bit of an odd setup.
I am using the route10 router and a USW switch from Ubiquiti (I’m slowly in the process of switching over to alta.inc).
I have my default VLAN and a separate VLAN on route10, but it seems like I can’t figure out how to do inter-vlan routing. I do not have Isolation turned on, on any of the VLANs.
Am I missing anything here?
Make sure you have the Vlan setup on the SWITCH
Native = 1 untagged and VLAN X as untagged on the TRUNK PORT
