Integration with Home Assistant
Hi all,
Not on board yet but doing research to replace the networking equipment at home I’ve reach here and so far, your products look quite interesting so basically waiting for the local controller and router to make a final decision.
One feature it will help me to decide is to know if there is any plan to get Alta Labs products integrated with Home Assistant. If there are plans for that, I think it will be a great feature to be added.
Both Mikrotik and Ubiquiti have integrations with Home Assistant and it is great to be able to enable/disable wifi, ports, poe,… based on local automations. Or even to monitor the powe budget or traffic.
If not a fully official Home Assistant integration, some kind of API to deal with will be great.
Thanks!
I mean the devices are running OpenWRT i think so shouldn’t be to hard to connect to. Not the mention the new local controller which I’m sure you can API into.
Is there any update on this in getting Alta Labs integrated into Home Assistant?
