[How To][Script] YouTube-only WireGuard policy routing helper script (dnsmasq/ipset + exclusions)
Hi everyone,
I’ve been experimenting with a YouTube-only WireGuard policy-routing setup on my Route10 and wanted to share the helper script I’m using in case it helps others or sparks improvements.
The goal is:
  • Keep normal LAN traffic going out the regular WAN.
  • Send only selected YouTube-related traffic through a WireGuard client tunnel.
  • Use dnsmasq + ipset to collect YouTube-related destination IPs.
  • Use iptables mangle + fwmark + a separate routing table to send those IPs through the tunnel.
  • Support an exclusion list for clients that should not use the VPN.
  • Use a local DNS server, such as Technitium, as dnsmasq’s upstream.
This is unofficial and definitely “use at your own risk.” Firmware updates or GUI changes may overwrite or interfere with pieces of it. I’m posting it mainly for community review, feedback, and improvement.
My setup:
  • Route10 with SSH access
  • WireGuard client created manually as wg-yt
  • dnsmasq upstream points to my local Technitium DNS server
  • LAN bridge is br-lan
  • Policy routing table is wgroute
  • YouTube ipset is yt-vpn
  • Optional excluded-client ipset is yt-src-exclude
High-level flow:
  1. Clients use the router as DNS.
  2. Router dnsmasq forwards upstream to Technitium.
  3. dnsmasq puts IPs for configured YouTube domains into yt-vpn.
  4. iptables marks packets whose destination is in yt-vpn.
  5. ip rule sends fwmark 0x200 to table wgroute.
  6. wgroute sends those packets out wg-yt.
  7. Excluded clients in yt-src-exclude hit a RETURN rule first and bypass the VPN.
Current domains included:
  • googlevideo.com
  • youtubei.googleapis.com
You can optionally add broader YouTube domains later, such as youtube.com, youtu.be, ytimg.com, or yt3.ggpht.com, but those can increase the chance that unrelated Google traffic also gets routed through the VPN.
Persistent files used:
  • /cfg/yt-vpn-setup.sh — main setup script
  • /cfg/yt-vpn.backup — optional saved warm ipset cache
  • /cfg/yt-src-exclude.list — optional list of excluded client IPs, one per line
Example exclusion file:
192.168.1.234
192.168.1.60
Script:
#!/bin/sh
# yt-vpn-setup-v2.sh
# Rebuilds YouTube-over-VPN on Alta/OpenWrt-style routers.
set -eu
umask 077
### ===== CONFIG: EDIT THESE =====
WG_PRIVKEY=""
WG_PSK=""                      # leave empty if unused
WG_ADDR=""                     # e.g. 100.68.101.47/32
WG_SERVER_PUBKEY=""
WG_ENDPOINT_HOST=""
WG_ENDPOINT_PORT="443"
TECHNITIUM_IP="192.168.1.19"
LAN_BRIDGE="br-lan"
WG_IF="wg-yt"
RT_TABLE_NAME="wgroute"
RT_TABLE_ID="200"
FWMARK="0x200"
YT_SET="yt-vpn"
EXCLUDE_SET="yt-src-exclude"
YT_BACKUP_FILE="/cfg/yt-vpn.backup"
EXCLUDE_FILE="/cfg/yt-src-exclude.list"   # optional, one IPv4 per line
FWU_BEGIN="# --- YT_VPN_WG_YT_SETUP BEGIN ---"
FWU_END="# --- YT_VPN_WG_YT_SETUP END ---"
info() { echo "[INFO] $*"; }
warn() { echo "[WARN] $*" >&2; }
err()  { echo "[ERROR] $*" >&2; }
die()  { err "$*"; exit 1; }
need_root() {
  [ "$(id -u)" = "0" ] || die "Run as root."
find_dnsmasq_section() {
  uci show dhcp 2>/dev/null | awk -F= '/=dnsmasq$/{print $1; exit}'
validate_ipv4() {
  echo "$1" | awk -F. '
    NF!=4 {exit 1}
      for(i=1;i<=4;i++) {
        if($i !~ /^[0-9]+$/ || $i < 0 || $i > 255) exit 1
    END{exit 0}'
validate_cidr() {
  case "$1" in
      addr=${1%/*}
      mask=${1#*/}
      return 1
  esac
  validate_ipv4 "$addr" || return 1
  echo "$mask" | awk 'BEGIN{ok=0} /^[0-9]+$/ && $1>=0 && $1<=32 {ok=1} END{exit ok?0:1}'
validate_port() {
  echo "$1" | awk 'BEGIN{ok=0} /^[0-9]+$/ && $1>=1 && $1<=65535 {ok=1} END{exit ok?0:1}'
status_dns() {
  if nslookup youtube.com 192.168.1.1 >/dev/null 2>&1; then
    echo "YES (query to 192.168.1.1 succeeded)"
  elif nslookup youtube.com 127.0.0.1 >/dev/null 2>&1; then
    echo "YES (query to 127.0.0.1 succeeded)"
  else
    echo "NO (query failed)"
  fi
status_mangle() {
  if iptables -t mangle -C PREROUTING -i "$LAN_BRIDGE" \
      -m set --match-set "$EXCLUDE_SET" src \
      -m set --match-set "$YT_SET" dst -j RETURN 2>/dev/null; then
    echo "PRESENT (RETURN+MARK mode)"
    return
  fi
      -m set --match-set "$YT_SET" dst -j MARK --set-mark "$FWMARK" 2>/dev/null; then
    echo "PRESENT (MARK mode)"
    return
  fi
  echo "MISSING"
print_status() {
  DNS_STATUS="$(status_dns)"
  if ip link show "$WG_IF" >/dev/null 2>&1; then WG_IF_OK="PRESENT"; else WG_IF_OK="MISSING"; fi
  if wg show "$WG_IF" 2>/dev/null | grep -q 'latest handshake:'; then WG_HS_OK="OK (seen)"; else WG_HS_OK="NOT SEEN"; fi
  if ip rule show | grep -q "fwmark $FWMARK lookup $RT_TABLE_NAME"; then RULE_OK="PRESENT"; else RULE_OK="MISSING"; fi
  if ip route show table "$RT_TABLE_NAME" 2>/dev/null | grep -q "default dev $WG_IF"; then RT_OK="PRESENT"; else RT_OK="MISSING"; fi
  if uci show "$DNSMASQ_SECTION".ipset 2>/dev/null | grep -q "$YT_SET"; then DNS_IPSET_OK="PRESENT"; else DNS_IPSET_OK="MISSING"; fi
  if grep -q "$FWU_BEGIN" /etc/firewall.user 2>/dev/null; then FWU_OK="PRESENT"; else FWU_OK="MISSING"; fi
  if ipset list "$YT_SET" >/dev/null 2>&1; then
    YT_COUNT="$(ipset list "$YT_SET" | awk '/^Number of entries:/{print $4}')"
    [ -n "$YT_COUNT" ] || YT_COUNT=0
  else
    YT_COUNT="MISSING"
  fi
  echo "================ YT-over-VPN STATUS ================"
  printf "%-34s %s\n" "Router DNS listener:" "$DNS_STATUS"
  printf "%-34s %s\n" "WireGuard interface $WG_IF:" "$WG_IF_OK"
  printf "%-34s %s\n" "WireGuard handshake:" "$WG_HS_OK"
  printf "%-34s %s\n" "ip rule fwmark -> $RT_TABLE_NAME:" "$RULE_OK"
  printf "%-34s %s\n" "Routing table $RT_TABLE_NAME:" "$RT_OK"
  printf "%-34s %s\n" "Mangle PREROUTING:" "$(status_mangle)"
  printf "%-34s %s\n" "dnsmasq ipset config:" "$DNS_IPSET_OK"
  printf "%-34s %s\n" "$YT_SET entries:" "$YT_COUNT"
  printf "%-34s %s\n" "/etc/firewall.user block:" "$FWU_OK"
  echo "===================================================="
is_configured() {
  ip link show "$WG_IF" >/dev/null 2>&1 || return 1
  ip rule show | grep -q "fwmark $FWMARK lookup $RT_TABLE_NAME" || return 1
  ip route show table "$RT_TABLE_NAME" 2>/dev/null | grep -q "default dev $WG_IF" || return 1
  uci show "$DNSMASQ_SECTION".ipset 2>/dev/null | grep -q "$YT_SET" || return 1
  grep -q "$FWU_BEGIN" /etc/firewall.user 2>/dev/null || return 1
  return 0
save_current_cache() {
    ipset save "$YT_SET" > "$YT_BACKUP_FILE" || true
  fi
restore_cache() {
  [ -f "$YT_BACKUP_FILE" ] || return 0
  ipset create "$YT_SET" hash:ip maxelem 65536 -exist
  grep '^add '"$YT_SET"' ' "$YT_BACKUP_FILE" | while read _ _ ip; do
    ipset add "$YT_SET" "$ip" -exist
  done
ensure_rt_table() {
  grep -q "^$RT_TABLE_ID[[:space:]]\+$RT_TABLE_NAME$" /etc/iproute2/rt_tables 2>/dev/null || \
    echo "$RT_TABLE_ID $RT_TABLE_NAME" >> /etc/iproute2/rt_tables
  ip route flush table "$RT_TABLE_NAME" 2>/dev/null || true
  ip route replace default dev "$WG_IF" table "$RT_TABLE_NAME"
ensure_wg() {
  [ -n "$WG_PRIVKEY" ] || die "WG_PRIVKEY is empty."
  [ -n "$WG_SERVER_PUBKEY" ] || die "WG_SERVER_PUBKEY is empty."
  [ -n "$WG_ENDPOINT_HOST" ] || die "WG_ENDPOINT_HOST is empty."
  validate_cidr "$WG_ADDR" || die "WG_ADDR is invalid: $WG_ADDR"
  validate_port "$WG_ENDPOINT_PORT" || die "WG_ENDPOINT_PORT is invalid: $WG_ENDPOINT_PORT"
  mkdir -p /cfg
  printf '%s\n' "$WG_PRIVKEY" > /cfg/wg-yt.key
  chmod 600 /cfg/wg-yt.key
  if [ -n "$WG_PSK" ]; then
    printf '%s\n' "$WG_PSK" > /cfg/wg-yt.psk
    chmod 600 /cfg/wg-yt.psk
  else
    rm -f /cfg/wg-yt.psk
  fi
  ip link del "$WG_IF" 2>/dev/null || true
  modprobe wireguard 2>/dev/null || true
  ip link add dev "$WG_IF" type wireguard
    wg set "$WG_IF" \
      private-key /cfg/wg-yt.key \
      peer "$WG_SERVER_PUBKEY" \
      preshared-key /cfg/wg-yt.psk \
      endpoint "$WG_ENDPOINT_HOST:$WG_ENDPOINT_PORT" \
      allowed-ips 0.0.0.0/0
  else
    wg set "$WG_IF" \
  fi
  ip addr flush dev "$WG_IF"
  ip addr add "$WG_ADDR" dev "$WG_IF"
  ip link set dev "$WG_IF" mtu 1380
  ip link set up dev "$WG_IF"
  wg set "$WG_IF" peer "$WG_SERVER_PUBKEY" persistent-keepalive 25
ensure_dnsmasq_config() {
  validate_ipv4 "$TECHNITIUM_IP" || die "TECHNITIUM_IP is invalid: $TECHNITIUM_IP"
  uci set "$DNSMASQ_SECTION".noresolv='1'
  uci del "$DNSMASQ_SECTION".server 2>/dev/null || true
  uci add_list "$DNSMASQ_SECTION".server="$TECHNITIUM_IP"
  uci del "$DNSMASQ_SECTION".ipset 2>/dev/null || true
  uci add_list "$DNSMASQ_SECTION".ipset='/googlevideo.com/yt-vpn'
  uci add_list "$DNSMASQ_SECTION".ipset='/youtubei.googleapis.com/yt-vpn'
  uci commit dhcp
  /etc/init.d/dnsmasq restart
render_firewall_block() {
  cat <<EOF
$FWU_BEGIN
ipset create $YT_SET hash:ip maxelem 65536 -exist
ipset create $EXCLUDE_SET hash:ip maxelem 128 -exist
if [ -f "$EXCLUDE_FILE" ]; then
  while IFS= read -r ip; do
    [ -n "\$ip" ] || continue
    case "\$ip" in \#*) continue ;; esac
    ipset add $EXCLUDE_SET "\$ip" -exist
  done < "$EXCLUDE_FILE"
fi
iptables -t nat -D POSTROUTING -o $WG_IF -j MASQUERADE 2>/dev/null || true
iptables -t nat -A POSTROUTING -o $WG_IF -j MASQUERADE
iptables -D FORWARD -o $WG_IF -j ACCEPT 2>/dev/null || true
iptables -D FORWARD -i $WG_IF -j ACCEPT 2>/dev/null || true
iptables -I FORWARD -o $WG_IF -j ACCEPT
iptables -I FORWARD -i $WG_IF -j ACCEPT
iptables -t mangle -D PREROUTING -i $LAN_BRIDGE -m set --match-set $EXCLUDE_SET src -m set --match-set $YT_SET dst -j RETURN 2>/dev/null || true
iptables -t mangle -I PREROUTING 1 -i $LAN_BRIDGE -m set --match-set $EXCLUDE_SET src -m set --match-set $YT_SET dst -j RETURN
iptables -t mangle -D PREROUTING -i $LAN_BRIDGE -m set --match-set $YT_SET dst -j MARK --set-mark $FWMARK 2>/dev/null || true
iptables -t mangle -A PREROUTING -i $LAN_BRIDGE -m set --match-set $YT_SET dst -j MARK --set-mark $FWMARK
ip rule del fwmark $FWMARK table $RT_TABLE_NAME 2>/dev/null || true
ip rule add fwmark $FWMARK table $RT_TABLE_NAME priority $RT_TABLE_ID
ip route flush table $RT_TABLE_NAME 2>/dev/null || true
ip route replace default dev $WG_IF table $RT_TABLE_NAME
$FWU_END
EOF
ensure_firewall_user() {
  tmp="$(mktemp)"
  if [ -f /etc/firewall.user ]; then
    awk -v begin="$FWU_BEGIN" -v end="$FWU_END" '
      $0==begin {skip=1; next}
      $0==end   {skip=0; next}
      !skip     {print}
    ' /etc/firewall.user > "$tmp"
  fi
  render_firewall_block >> "$tmp"
  cp "$tmp" /etc/firewall.user
  rm -f "$tmp"
  /etc/init.d/firewall restart
full_setup() {
  save_current_cache
  ensure_wg
  ensure_rt_table
  restore_cache
  info "Setup complete."
  info "Server peer must allow router address $WG_ADDR and router public key from: wg show $WG_IF"
main() {
  need_root
  DNSMASQ_SECTION="$(find_dnsmasq_section)"
  [ -n "$DNSMASQ_SECTION" ] || die "Could not find dnsmasq UCI section."
  print_status
  if is_configured; then
    printf "Do you want to reconfigure it now? [y/N] "
    read ans
    case "$ans" in
      y|Y|yes|YES) full_setup ;;
      *) info "No changes made." ;;
    esac
  else
    printf "Do you want to configure it now? [y/N] "
    read ans
    case "$ans" in
    esac
  fi
main "$@"
Usage:
chmod +x /cfg/yt-vpn-setup.sh
Basic checks after running:
wg show wg-yt
ip rule show
ip route show table wgroute
iptables -t mangle -L PREROUTING -n -v --line-numbers
uci show $(uci show dhcp | awk -F= '/=dnsmasq$/{print $1; exit}').server
Expected behavior:
  • wg-yt has a recent handshake.
  • ip rule has fwmark 0x200 lookup wgroute.
  • wgroute has default dev wg-yt.
  • mangle has a RETURN rule for excluded sources and a MARK rule for yt-vpn.
  • dnsmasq server is your Technitium IP.
  • yt-vpn is restored if /cfg/yt-vpn.backup exists.
Exclusion list:
Example:
192.168.1.234
Thank you to the Alta community for all the previous discussion around Route10, WireGuard client use, policy routing, and tcpdump/SSH troubleshooting. I’d appreciate any feedback on making this cleaner, safer, or more compatible with future firmware updates.
Updated :
#!/bin/sh
# yt-vpn-setup.sh
set -eu
umask 077
WG_PRIVKEY=""
WG_SERVER_PUBKEY=""
WG_ENDPOINT_HOST=""
WG_ENDPOINT_PORT=""
TECHNITIUM_IP=""
LAN_BRIDGE="br-lan"
WG_IF="wg-yt"
ROUTER_DNS_IP=""               # router LAN DNS IP; auto-detected from LAN_BRIDGE if empty
WG_MTU="1440"                  # tunnel MTU; 1440 suits a 1500 (baby-jumbo) PPPoE WAN (1500-60). Use 1432 on a 1492 WAN.
WG_KEEPALIVE="25"
RT_TABLE_ID="200"
RULE_PRIORITY="200"            # ip rule priority for the fwmark policy rule
FWMARK="0x200"
YT_SET="yt-vpn"
need_root() {
check_deps() {
  for cmd in ipset iptables wg uci awk; do
    command -v "$cmd" >/dev/null 2>&1 || die "Required command not found: $cmd"
  done
  if [ ! -d /sys/module/wireguard ] && ! grep -qw wireguard /proc/modules 2>/dev/null; then
    if ip link add dev wgprobe$$ type wireguard 2>/dev/null; then
      ip link del wgprobe$$ 2>/dev/null || true
    else
      die "WireGuard kernel support not available (modprobe wireguard failed)."
    fi
  fi
  # dnsmasq must be built with ipset support (dnsmasq-full); plain dnsmasq
  # silently ignores the ipset= directive and yt-vpn never populates.
  if dnsmasq --version 2>/dev/null | grep -qi 'no-ipset'; then
    die "Installed dnsmasq lacks ipset support (need dnsmasq-full)."
  fi
detect_router_ip() {
  ip -4 addr show "$LAN_BRIDGE" 2>/dev/null | awk '/inet /{sub("/.*","",$2); print $2; exit}'
validate_ipv4() {
    NF!=4 {exit 1}
      for(i=1;i<=4;i++) {
    END{exit 0}'
validate_cidr() {
  local addr mask
  case "$1" in
      addr=${1%/*}
      mask=${1#*/}
      return 1
  esac
validate_port() {
status_dns() {
  local router_ip
  router_ip="${ROUTER_DNS_IP:-$(detect_router_ip)}"
  if [ -n "$router_ip" ] && nslookup youtubei.googleapis.com "$router_ip" >/dev/null 2>&1; then
    echo "YES (query to $router_ip succeeded)"
  elif nslookup youtubei.googleapis.com 127.0.0.1 >/dev/null 2>&1; then
  else
  fi
status_mangle() {
    return
  fi
    return
  fi
  echo "MISSING"
print_status() {
  else
    YT_COUNT="MISSING"
  fi
is_configured() {
  return 0
  local cnt
  ipset list "$YT_SET" >/dev/null 2>&1 || return 0
  cnt="$(ipset list "$YT_SET" | awk '/^Number of entries:/{print $4}')"
  # Don't overwrite a good backup with an empty/flushed set.
  [ "${cnt:-0}" -gt 0 ] 2>/dev/null || return 0
restore_cache() {
  # Fast path: ipset restore consumes the `ipset save` format directly.
  # -! tolerates the existing set/entries; fall back to a per-entry loop
  # if the dump format is rejected.
  if ! ipset restore -! < "$YT_BACKUP_FILE" 2>/dev/null; then
    done
  fi
ensure_rt_table() {
ensure_ipsets() {
  # Create the sets up front so dnsmasq has somewhere to add resolved IPs as
  # soon as it restarts; firewall.user re-creates them with -exist on boot.
  ipset create "$EXCLUDE_SET" hash:ip maxelem 128 -exist
ensure_wg() {
  mkdir -p /cfg
  else
  fi
    wg set "$WG_IF" \
  else
    wg set "$WG_IF" \
  fi
  ip link set dev "$WG_IF" mtu "$WG_MTU"
  wg set "$WG_IF" peer "$WG_SERVER_PUBKEY" persistent-keepalive "$WG_KEEPALIVE"
  # Media CDN: the actual videoplayback audio/video streams.
  # InnerTube player API used by the mobile/TV/embedded clients.
  # Web front-end + player config. The request that MINTS the IP-locked
  # videoplayback URLs (www.youtube.com/youtubei/v1/player on desktop) must
  # egress the SAME VPN IP as the media, or the signed ip= in those URLs
  # won't match the stream source and Google throttles/redirects.
  # dnsmasq matches by suffix, so /youtube.com/ also covers www. and m.
  uci add_list "$DNSMASQ_SECTION".ipset='/youtube.com/yt-vpn'
  uci add_list "$DNSMASQ_SECTION".ipset='/youtube-nocookie.com/yt-vpn'
  # Static assets (thumbnails, avatars) — optional, for a fully coherent path.
  uci add_list "$DNSMASQ_SECTION".ipset='/ytimg.com/yt-vpn'
  uci add_list "$DNSMASQ_SECTION".ipset='/ggpht.com/yt-vpn'
  uci commit dhcp
  cat <<EOF
$FWU_BEGIN
fi
# Clamp TCP MSS to the tunnel path MTU so large segments don't get dropped
# (PMTU black-holes are a common cause of YouTube buffering over a tunnel).
# QUIC/HTTP3 (UDP 443) does its own PMTU discovery and is unaffected.
iptables -t mangle -D FORWARD -o $WG_IF -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 2>/dev/null || true
iptables -t mangle -D FORWARD -i $WG_IF -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 2>/dev/null || true
iptables -t mangle -A FORWARD -o $WG_IF -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
iptables -t mangle -A FORWARD -i $WG_IF -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
# Append our two mangle rules after any existing PREROUTING rules so the
# router's own firewall rules keep their precedence. The RETURN (exclude)
# rule must sit immediately above the MARK rule, so append RETURN first.
iptables -t mangle -A PREROUTING -i $LAN_BRIDGE -m set --match-set $EXCLUDE_SET src -m set --match-set $YT_SET dst -j RETURN
while ip rule del fwmark $FWMARK table $RT_TABLE_NAME 2>/dev/null; do :; done
ip rule add fwmark $FWMARK table $RT_TABLE_NAME priority $RULE_PRIORITY
$FWU_END
EOF
  local tmp
  tmp="$(mktemp)"
      !skip     {print}
  fi
  rm -f "$tmp"
full_setup() {
  check_deps
  save_current_cache
  ensure_wg
  ensure_rt_table
  ensure_ipsets
  restore_cache
main() {
  local ans
  need_root
  print_status
  else
  fi
  read ans || ans=""
  case "$ans" in
  esac
main "$@"
