Hi,
Like in topic is there a way to enable Wan2 port on route10? Right now I don’t have main ISP, and ISP 2 is connected but port is right now disabled and I can’t access to controller without internet.
Hi,
If we’re saying the interface is down and we’re in the terminal then I think ifup and ifdown should do it.
So in this case ifup wan2 should result in the corresponding message in the syslog (/var/log/messages) daemon.notice netifd: Interface 'wan2' is enabled.
nope, thats not work.
Fortunately, the main provider fixed the connection and I can get to the panel.
