Anyone else with a AP6 Pro have a very high pitched sound? Sitting at my desk and the AP across the room can very clearly hear it. Maybe I got a dud?
I’ve also noticed this with the Pro’s, not so much the standard AP’s.
In fact, I returned one due to this, only to discover that the replacement made the same high pitch frequency noise.
Haven’t seen it impact performance.
I worked a lot with the AP Pro in close proximity in the last few weeks and did not hear anything, infact I did not see anything movable when I opened it up, so it might be a faulty IC in yours. ![]()
This is the first I’ve ever heard of this. How are you powering your units?
Jeff,
I have two AP-Pro’s
1 - Directly attached to a Route10 - PoE
2 - Directly attached to an S16 - PoE
Both produce the same sound. I’ve also attempted to migrate all AC power to a completely different circuit.
Once again, I haven’t seen an impact on performance, but I’ve yet to migrate my existing network to the Alta stack. Only time will tell.
I’ll consider this option.
Thank you!
