Quick question regarding density and the AP6. I may have a possible installation at a large facility. The amount of AP’s will be ~20. Expected users will exceed 1500 devices connected. Will the AP6 be able to handle a large amount of devices connected?
Hi @Z-Tech! Yes, the APs can handle hundreds to thousands of WiFi devices if you create a password using the Large password type.
Will the hundreds to thousands also work on an open network? We require an open network and over 1000 devices will connect to it.
Yes, when you select the Open option, in the advanced settings it will give you the different networks types to choose from. For 1,000 devices we would recommend having 10-15 APs maybe more just to handle the load.
