need info on creating ssh keys and how to use them please
is the creation of ssh keys to allow me access to the aps
@regchan To create an ssh-key, you can use “ssh-keygen” from any Mac or Linux system. This will create an “id_rsa” and “id_rsa.pub” file in your home directory’s “.ssh” directory. All you need to do is copy and paste the contents of the “id_rsa.pub” file into our web UI, and then you should be able to ssh into the APs as the “root” user:
$ ssh root@192.168.1.50
BusyBox v1.33.1 (2021-10-24 09:01:35 UTC) built-in shell (ash)
finally logged in with SSH key
You’re a hacker now ![]()
As I came across this post after reaching some failures, I wanted to at least share my experience.
At this time of this writing, it appears that ssh key is limited to a simple RSA keygen.
I tried using ed25519 but that failed.
I tried using rsa -b 4096 but that also failed.
I did not even tried to make a comment as part of the ssh keygen.
Using POP!_OS 22.04 LTS, I used the following commands:
ssh-keygen -t rsa -f id_rsa-ap6pro-simple-first
If you use an .ssh/config, you can add this entry:
Host appro6
Host appro6.mydomain.tls
User root
IdentityFile ~/.ssh/id_rsa-ap6pro-simple-first
hope this helps…
i used putty gen to create my keyg gen files
PuTTY is the GUI ssh client.
PuTTYgen is the application that would generate keys.
TL;DR (on the above link), but I did a quick scan and saw that it was reference rsa.
ed25519 is a recommended because the public-key is smaller than RSA as well as being more secure.
Given that Alta is a newer company/hardware line, I was hoping other ssh keys could be used.
I followed this 5 or 6 times now using MacOS and uploaded the contents of the pub file to your portal under SSH keys.
Whatever I do I get the error root@192.168.4.2: Permission denied (publickey)
Has something changed since this article or am I missing something obvious?
I managed to get this working in the end. Not quite as simple as this thread suggests because you have to specify your ssh key file in the ssh command when making the connection.
Hello, can you clarify what you did? I’m having trouble with MacOS as well
I’ll have to double check but I believe I just specified -t rsa during the keygen on my MacBook
I am attempting to use iperf between 2 Alta AP’s using Terminal on a MAC.
ssh root@192.168.1.194 (How if it is a remote connection?)
passphrase
iperf3 -s (192.168.1.194 AP is the server)
(Do I need to open a new Terminal window to access the IP of the client?)
If I do open a new Terminal window then:
ssh root@192.168.1.167 (How if it is a remote connection?)
passphrase
iperf3 -c 192.168.1.194 --bidir -P 10 -t 30 -w 512k
Now both windows show: socket buffer size not set correctly (how/where can I change this?)
Do I need to open 2 Terminal windows?
What if this were a remote connection to Alta?
